I can't get new programmes to run
Hello,
        Hope this doesn't sound too daft! I've just started using grass4.1 agai
n
after an 18 month break - I've got it newly compiled on a SunSparc 10. The
source code and alpha source code is running fine - but I can't get any of the
contributed code to work, either in the 4.1 release or from the incoming site o
n
the moon.
        The code is there with all it's directories - I go into the program roo
t
directory type gmake4.1 - it compiles the program, creating the OBJ directory.
Then I go back up to the directory holding the new command, type (for example)
v.circle <enter>
and get the response
v.circle: permission denied.
everything is read-writable - I've made sure of that, does anybody know whats
gone wrong?
Al Duncan.
remember you have to run the script MAKELINKS again.
Agus
