dear friends:
I am using for digitizing maps the program AUTOCAD version 12 installed
in a PC (IBM Compatible). Now I need to use those maps in a GIS Grass4.
1
installed in a Workstation SUN sparc Solaris.
the maps was saved with a DXF format in a diskette 1.44 HD (format for
windows pc ) and I don't know how I can use it in a workstation with an
d
operation system UNIX.
please it will be useful to receive some answer to solve my problem
thanks
claudio szlafztein
geological departament
University of Para
Brazil
iosele@marajo.ufpa.br
If you are having trouble copying the files of the DOS disk to your UNIX
box, there is a package called mtools, that I believe woeks on suns to read
a DOS diskette. If you can read the diskette, you can just use v.in.dxf to
import your files into your map.
Hope that helps, Phillip Dillinger
