Good Afternoon
I'm interested to know how folks are importing spot images into Grass if these
images are not on tape.
I have been simply copying these image files into a cell directory in my
MAPSET directory and then viewing them with the help of r.support as raster
files.
I run into difficulties however when trying to reference the images.
While using d.what.rast I find that the areas I am interested in on the image
do not correspond with those on my hard copy map. Even though the region
I specify ( UTM zone 14) is correct.
Any suggestions as to how I can correctly read these images in ? The tutorial
gives information on Tape Extraction but nothing else.
Thank you
Jeremy
Wang Song developed a script to extract SPOT imagery from CD. Wang has
left CAST but I think that Rob Dzur (rob@cast.uark.edu) may be able to
track down the scripts....
On Fri, 7 Jul 1995, DUNN JEREMY SIMON wrote:
Good Afternoon
e
files.
Thank you
Jeremy
W. Fredrick Limp, Director and Professor FAX: (501) 575-5218
CAST, Center for Advanced Spatial Technologies TEL: (501) 575-6159
12 Ozark Hall, U of Ark., Fayetteville AR 72701 fred@cast.uark.edu
Opinions expressed here are mine, at least I think they are.
