Importing from ArcInfo
Hi mate,
To make your attribute file, follow the following commands in INFO;
sel <filename.pat>
list
CALC $COMMA-SWITCH = -1
ITEMS
OUTPUT /path/filename.txt
DISPLAY $RECNO,<FILENAME#>,<FILENAME-ID>,ATTRIBUTE,ATTRIBUTE,ETC. PRINT
OUTPUT arcsnp
q stop
I hope this would help.
Greetings,
I am trying to import an existing polygon coverage from ArcInfo using
v.in.arc. I get the polygon and label points from the ArcInfo ungenerate
command but cannot get the label text file to identify the polygons (as
forest types).
Anybody know how? The Grass on-line manual suggests the ArcInfo DISPLAY
command but gives no other information.
Thanks
Thom Meredith
Tarek Sadek
Ph.D. Student
Department of Civil and Environmental Engineering
University of Melbourne
Parkville, Vic. 3052
Australia
Tel: +03 344 7178
Fax: +03 344 6215
E-mail address: sadek@aqua.civag.unimelb.edu.au
