Is it possiblle to filter the dropdown list for a WPS input, based on criteria, for example number of bands or metadata value? Maybe through the meta tag in @DescribeParameter somehow?
In my case, I would like to filter a Coverage2D input.
Because you mention drop-down-list I expect you make be talking specifically about the WPS Request builder. The @DescribeParameter does have the ability to list options, not sure exactly if the WPS Request Builder respects those or not.
The metadata map stores constraints, and a few keys like “min” and “max” and “password” have associated methods for access. Presently “options” is just documented with a javadoc, but if it is popular a helper method could be made.
* As an alternative to "min" and "max" a speciifc List<T> of options can be provided for a user to choose between.
* The description should explain what the options mean.
* <p>Example: a compliance level of (0-low,1-medium,2-high)
* <p>Although a List<T> is used here (so you can specifiy order) it is assumed you will not confuse your users by
* placing duplicates in the list.
public static final String OPTIONS = "options";
