Introduction - Sakir Ahmed - GSoC 2026 pgRouting
Tell us about yourself:
I’m a CS student pursuing BTech in AI, I came across pgRouting while contributing on grass GIS and spent time going through the project history, past student wikis, and the contribution process. The mix of graph algorithms, C++, and PostgreSQL is exactly the kind of work I want to get into.
Any OSGeo projects and communities you are involved in:
I’ve been contributing to GRASS GIS (OSGeo). My work has been focused on the test suite migration converting legacy shell based tests to pytest for the t.rast.mapcalc module
(PRs #6948 and #6897 and also #6967).
This involved migrating shell tests to pytest, setting up proper GRASS session fixtures, using the Tools API, writing assertions for map counts and temporal types, and handling teardown correctly across CI environments.
I went through multiple review cycles with maintainers (petrasovaa, ninsbl) which taught me a lot about how the project expects tests to be structured.
In pgRouting, I submitted PR #3063 which enabled the clang-tidy cppcoreguidelines-explicit-virtual-functions check and fixing violations across C++ headers was merged and added to the release 4.1.0 milestone.
What do you want to learn / contribute:
PR #3063 got me familiar with pgRouting’s C++ internals for the first time. I want to go further learn how a full algorithm gets built into the codebase end-to-end, from the C++ core to the SQL interface, docs, and tests. The GSoC project feels like the right way to do that properly.
Tech Stack:
  • Languages: C++, Python, SQL, JavaScript, HTML5
  • Databases: PostgreSQL (plpgsql), MySQL, MongoDB
  • Frontend: React
  • Tools: Git, docker, kubernetes
Links:
Sakir,
Welcome,
To get started with GSOC 2026, please follow the pgRouting 2026 guidelines - GSoC Ideas: 2026 · pgRouting/pgrouting Wiki · GitHub and monitor and interact in the pgrouting-dev - OSGeo Discourse
hey @robe @cvvergara i hope you all are doing well,
I submitted my final GSoC proposal for Planar Faces and K-Core Decomposition! I did want to make one quick correction, im really sorry it was a mistake from my side I stated that pgr_isPlanar does not exist, but I recently realized it actually exists in the experimental module. After submitting, I kept digging into the codebase and realized it was introduced in v3.2.0 and in my proposal i stated “it would be built from scratch”
So, to clarify my plan: instead of building it from scratch, my goal will be to audit the existing pgr_isPlanar code, add the missing pgTap tests, and use it as the stabilized foundation for my pgr_planarFaces implementation.
Hi @sakirr05
We will revise your final proposal during the bonding period.
The pgr_isPlanar we knew that it exists, but the Planar faces and K core decomposition was the ones that interest us more.
definitively you will not be doing anything on pgr_isPlanar:
  • not audit the existing code, which belongs to boost
  • not adding pgTap tests,
    the pgr_isPlanar is just simply connecting the data with the boost code.
Once we revise during the bonding period, 90% of the time you will focus on your and only your tasks, 10% is the meetings and helping each other.
Regards
Vicky
(dont forget to put emoji when you read any of the mentors)
Hi @cvvergara,
Thank you for the clarification , that makes things much clearer.
