is there a programming error in r.tiff.in.?
Hi Peter,
Actually I am using r.in.tiff module, but I haven't really solved the problem!
In fact what I have done is install RedHat 6.0 and GRASS ver4.3 (at the
moment I don't need floating point capabilities) and it works!
I still don't understand if its a libraries mismatch or a r.in.tiff module
bug, maybe both? the problem is that I started to use GRASS and Linux one
mounth ago.
bye
Sabrina
At 16.20 05/04/00 -0230, you wrote:
Hi Sabrina. I was just wondering if you ever got the r.tiff.in module
working properly in GRASS and if so what you did to fix the problem?
Peter Earle
Biology Department
Memorial University
St. John's, NF
Canada
A1B 3X9
On Sun, 21 Feb 1999, Sabrina Agnesi wrote:
Hello GRASS comunity,
I'm very new to Linux OS and GRASS. I have on my PC Linux (Mandrake7) and
GRASS (ver5.6beta).
I am attempting to import a tiff file using r.in.tiff command, and first I
got a message saying that it could not locate shared library libjpeg.so.6.
So in /usr/lib I found libjpeg.so.62.0.0 and created a link to it called
libjpeg.so.6. Then I ran ldconfig. Boot the machine and then when I run
r.in.tiff I get a segmentation fault error...
I check in the mailing list and realize that I'm not the only one that have
this problem,
Do you know where I can find the libraries in the net? supposing is library
mismatch!
Does anybody fix the problem?
Thanks
Sabrina
