I’m running into problems when trying to use <ChannelSelection> in a <RasterSymbolizer> style. Here is a small example that doesn’t work for me:
<StyledLayerDescriptor xmlns="http://www.opengis.net/sld" xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc" version="1.0.0" xmlns:sld="http://www.opengis.net/sld">
<UserLayer>
<UserStyle>
<FeatureTypeStyle>
<Rule>
<RasterSymbolizer>
<ChannelSelection>
<RedChannel>
<SourceChannelName>1</SourceChannelName>
</RedChannel>
<GreenChannel>
<SourceChannelName>2</SourceChannelName>
</GreenChannel>
<BlueChannel>
<SourceChannelName>3</SourceChannelName>
</BlueChannel>
</ChannelSelection>
</RasterSymbolizer>
</Rule>
</FeatureTypeStyle>
</UserStyle>
</UserLayer>
</StyledLayerDescriptor>
The style works if I don’t include <ChannelSelection> at all, or if I include only one or two channels, but not all three.
My server setup is: GeoServer version 2.26.2, openjdk version 17.0.16 and Ubuntu 24.04.2 LTS.
The raster I’m trying to style comes from an ImagePyramid data source. Running gdalinfo on one of the files in the dataset produces:
Size is 163840, 163840
Coordinate System is:
ENGCRS["WGS 84 / Pseudo-Mercator",
EDATUM["Unknown engineering datum"],
CS[Cartesian,2],
AXIS["(E)",east,
ORDER[1],
LENGTHUNIT["metre",1,
ID["EPSG",9001]]],
AXIS["(N)",north,
ORDER[2],
ID["EPSG",9001]]]]
Data axis to CRS axis mapping: 1,2
Origin = (2346880.000000000000000,10496280.000000000000000)
Pixel Size = (0.250000000000000,-0.250000000000000)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
SOURCE_COLOR_SPACE=YCbCr
COMPRESSION=YCbCr JPEG
INTERLEAVE=PIXEL
JPEG_QUALITY=50
JPEGTABLESMODE=1
Corner Coordinates:
Upper Left ( 2346880.000,10496280.000)
Lower Left ( 2346880.000,10455320.000)
Upper Right ( 2387840.000,10496280.000)
Lower Right ( 2387840.000,10455320.000)
Center ( 2367360.000,10475800.000)
Band 1 Block=512x512 Type=Byte, ColorInterp=Red
Mask Flags: PER_DATASET
Band 2 Block=512x512 Type=Byte, ColorInterp=Green
Band 3 Block=512x512 Type=Byte, ColorInterp=Blue
(I ran this on my local machine where there is an issue with the reference to the proj DB at them moment, hence the weird coordinate system)
Below is the error log from when I try to call the WMS layer using this styling.
Could this be a bug or I’m I doing something wrong?
Thanks!
12 Nov 08:31:25 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Error rendering coverage on the fast path
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:291)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:198)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:81)
at org.geoserver.wms.GetMap.executeInternal(GetMap.java:327)
at org.geoserver.wms.GetMap.run(GetMap.java:199)
at org.geoserver.wms.GetMap.run(GetMap.java:113)
at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:245)
at jdk.internal.reflect.GeneratedMethodAccessor235.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:569)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:344)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:198)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:163)
at org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:38)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:55)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:31)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:63)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:43)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:51)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:241)
at jdk.proxy3/jdk.proxy3.$Proxy119.getMap(Unknown Source)
at jdk.internal.reflect.GeneratedMethodAccessor245.invoke(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:868)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:262)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:177)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:51)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1072)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:965)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:1006)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:898)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:883)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.jetty.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1459)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799)
at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1656)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.eclipse.jetty.servlet.FilterHolder.doFilter(FilterHolder.java:193)
at org.eclipse.jetty.servlet.ServletHandler$Chain.doFilter(ServletHandler.java:1626)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70)
at org.geoserver.ows.HTTPHeadersCollector.doFilter(HTTPHeadersCollector.java:48)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:67)
at org.geoserver.filters.HTTPMethodFilter.doFilter(HTTPMethodFilter.java:36)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:177)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:41)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:39)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:352)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at org.springframework.security.web.access.intercept.AuthorizationFilter.doFilter(AuthorizationFilter.java:100)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:89)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:361)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:126)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:120)
at org.geoserver.security.GeoServerAuthenticationKeyFilter.doFilter(GeoServerAuthenticationKeyFilter.java:100)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:200)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:117)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:80)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilterInternal(GeoServerSecurityContextPersistenceFilter.java:66)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:225)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:190)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:139)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:354)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:267)
at org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:108)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
at org.eclipse.jetty.servlets.CrossOriginFilter.handle(CrossOriginFilter.java:319)
at org.eclipse.jetty.servlets.CrossOriginFilter.doFilter(CrossOriginFilter.java:273)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:201)
at org.eclipse.jetty.servlet.FilterHolder.doFilter(FilterHolder.java:201)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:552)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:600)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1440)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:505)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1355)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:191)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:146)
at org.eclipse.jetty.server.Server.handle(Server.java:516)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:487)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:732)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:479)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105)
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034)
at java.base/java.lang.Thread.run(Thread.java:840)
Caused by: org.geoserver.platform.ServiceException: java.lang.IllegalArgumentException: The number of image bands (4) differs from the number of supplied {2} objects (3).
at org.geoserver.wms.map.DirectRasterRenderer.render(DirectRasterRenderer.java:296)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:289)
... 144 more
Caused by: java.lang.IllegalArgumentException: The number of image bands (4) differs from the number of supplied {2} objects (3).
at org.geotools.coverage.grid.RenderedSampleDimension.create(RenderedSampleDimension.java:93)
at org.geotools.coverage.grid.GridCoverage2D.<init>(GridCoverage2D.java:182)
at org.geotools.coverage.grid.GridCoverageFactory.create(GridCoverageFactory.java:539)
at org.geotools.gce.imagemosaic.RasterLayerResponse.prepareCoverage(RasterLayerResponse.java:1204)
at org.geotools.gce.imagemosaic.RasterLayerResponse.processRequest(RasterLayerResponse.java:592)
at org.geotools.gce.imagemosaic.RasterLayerResponse.createResponse(RasterLayerResponse.java:554)
at org.geotools.gce.imagemosaic.RasterManager.read(RasterManager.java:1210)
at org.geotools.gce.imagemosaic.ImageMosaicReader.read(ImageMosaicReader.java:626)
at org.geotools.gce.imagemosaic.ImageMosaicReader.read(ImageMosaicReader.java:608)
at org.geotools.gce.imagepyramid.ImagePyramidReader.loadRequestedTiles(ImagePyramidReader.java:372)
at org.geotools.gce.imagepyramid.ImagePyramidReader.read(ImagePyramidReader.java:330)
at org.geoserver.catalog.SingleGridCoverage2DReader.read(SingleGridCoverage2DReader.java:141)
at org.geoserver.catalog.CoverageDimensionCustomizerReader.read(CoverageDimensionCustomizerReader.java:221)
at org.geoserver.catalog.CoverageDimensionCustomizerReader.read(CoverageDimensionCustomizerReader.java:210)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageReaderHelper.readSingleCoverage(GridCoverageReaderHelper.java:619)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageReaderHelper.readCoverageInEnvelope(GridCoverageReaderHelper.java:389)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageReaderHelper.readCoverages(GridCoverageReaderHelper.java:278)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.renderImage(GridCoverageRenderer.java:712)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.renderImage(GridCoverageRenderer.java:668)
at org.geoserver.wms.map.DirectRasterRenderer.readWithProjectionHandling(DirectRasterRenderer.java:692)
at org.geoserver.wms.map.DirectRasterRenderer.render(DirectRasterRenderer.java:249)
... 145 more
