Issue with GeoServer COG Community Module - "Range downloading not supported" for local files
Hi everyone,
I am trying to use the COG (Cloud Optimized GeoTIFF) community module in GeoServer to serve a local 1.6 GB GeoTIFF file, but I am consistently hitting a “Range downloading not supported” error when trying to publish or access the layer via QGIS.
System Environment:
GeoServer Version: [Buraya GeoServer versiyonunu yaz, örn: 2.26.x]
Plugin: COG Community Module
OS: Linux (Ubuntu/Debian)
Problem Description:
I have uploaded my .tif file to the GeoServer www directory. When I attempt to create a new Store using the “Cloud Optimized GeoTIFF” format, I encounter the following issues:
Local File Access: I am using the URL file:www/Ekx/cog3.tif. However, in the COG Settings under “Range Reader settings”, the only available options are HTTP, S3, GS, and Azure. There is no “File” or “Local” option.
QGIS Error: When trying to add the layer in QGIS via /vsicurl/https://…, I get the error: desteklenmeyen bir raster veri kaynağı Range downloading not supported by this server!.
Permissions: I have already verified file permissions. The folder is set to 755 and the .tif file is set to 644.
What I have tried:
Converted the original TIFF to a proper COG layout using GDAL: gdal_translate input.tif output.tif -of COG -co COMPRESS=DEFLATE.
Tried both file: and https: URLs in the Store configuration.
Checked the “Cloud Optimized GeoTIFF (COG)” checkbox in the Store settings.
Question:
How can I properly configure the COG module to read local files from the disk without triggering the HTTP Range Request error? Is there a specific configuration needed for the Jetty/Tomcat server to support Range Requests for static files in the www folder, or should I be using a different Store type for local COGs?
Any help or guidance would be greatly appreciated.
Best regards,
COG is optimised for Cloud not local files, so the HTTP Range Request will not work in your scenario: file:www/Ekx/cog3.tif
My understanding is that the GeoServer www is not a high end web server, it’s quite basic.
Try hosting your COG differently directly under Tomcat? It should work, according to the first docs above (cog-http)
Peter
