Hello, @cvvergara @robe Actually I was solving issue#2628 and I was trying to verify my changes so I followed this documentation but this didn’t work properly : https://docs.pgrouting.org/latest/en/pgr_nodeNetwork.html . Could you please guide me with this. The error I faced is :
Saloni-2005_routing=# SELECT pgr_nodeNetwork(‘edges’, 0.001);
NOTICE: PROCESSING:
NOTICE: id: id
NOTICE: the_geom: the_geom
NOTICE: table_ending: noded
NOTICE: rows_where:
NOTICE: outall: f
NOTICE: pgr_nodeNetwork(‘edges’, 0.001, ‘id’, ‘the_geom’, ‘noded’, ‘’, f)
NOTICE: Performing checks, please wait …
NOTICE: -------> edges NOT found
pgr_nodenetwork
FAIL
(1 row)
Could you please highlight what I did wrong or how to resolve?
Thankyou!
robe
January 27, 2025, 3:56pm
2
Do you have an edges table? That error sounds like it can’t find the edges table.
I don’t have actually. How can I create one ?
robe
January 27, 2025, 5:58pm
4
You can also create from real data which is detailed in the workshop pgr_NodeNetwork - 1. Prepare Data — Workshop - FOSS4G Belém - Routing with pgRouting
AS @cvvergara has stated before, the best way to understand pgrouting and to help is try to go thru the workshop and figure out what might be made clearer and make sure all the steps are followable.
Also Look at some of the sample data files in docqueries
like this one:
pgrouting/docqueries/src/sampledata.result at main · pgRouting/pgrouting · GitHub or
this one - pgrouting/docqueries/src/concepts.result at main · pgRouting/pgrouting · GitHub
pgr_nodeNetwork has a lot of problems.
Please skip that one.
Hello @robe , @cvvergara ,
I just wanted to know if I can add more pgtap test cases for pgr_topologicalSort and add raise its PR.
Thankyou!
Hello @Saloni-2005
Sure you can:
Edge cases are simple as possible
Use the sample data of the documentation when possible
Recommendation if they do not exist
Topological sort of an empty graph
Topological sort of a graph with one node graph
Topological sort of a graph with two nodes graph (one edge)
Topological sort of a graph with two nodes graph (two edges)
Topological sort of a graph with three nodes graph (a - b - c)
Topological sort of a graph with three nodes graph (a - b - c - a)
Topological sort of a graph with three nodes graph (a - {b, c})
etc.
As many with no more than 5 nodes.
@Saloni-2005 , please don’t forget you need t o compile develop branch from the main repository for task #3
Hello @cvvergara mam,
Actually, I emailed you to review my proposal, but I haven’t received a response yet. Could you kindly take a look at it?
Found the mail got lost in between many mails I get.
Could not add comments to your proposal could only read.
I think I sent you a mail about requesting access.
but please make it to who has the link can add comments as I need to pass it to the other mentors.
Hello @cvvergara mam, I have updated the proposal after getting reviewed. Could you please review it again.
