Bonnie Weller writes:
I want to display labels to the monitor. Can this be done using GRASS?
I tried using d.paint.labels without luck. The labels will display
using p.map but I cannot draw labels from the command line.
d.paint.labels should do the job; remember that d.paint.labels can only
display labels previously defined with d.labels or p.labels. Check the
label-file and your region settings, I suggest.
How can I display labels for vector and raster files.
the easiest way is writing a script that takes the vector attributes and
transforms them to labels. I never tried this for vector maps, but for
site_lists it worked fine. For raster maps I don't see a quick solution,
as there are no centroids defined as far as I know.
Can labeling to the screen be done or should I forget it and wait to
do annotation when we switch over to ARC/Info next year ??
Only if you don't need them before next year!
Good luck,
Philip Verhagen
S t i c h t i n g R A A P
Regionaal Archeologisch Archiverings Projekt
adress: Plantage Muidergracht 14
1018 TV Amsterdam
THE NETHERLANDS
phone: (31) 20 525 5835
fax: (31) 20 525 5834
e-mail: motte@xs4all.nl
