we have upgraded from 2.19.2 to 2.27.2 version.
after upgrade, when created layers in UI.
Fields Native SRS and Declared SRS are not loading automatically.
Please advise how to fix issue?
Satish
Satish
Hi @Satish the info we have about your issue is insufficient to have a clue. I would recommend to set your GeoServer logging level to GEOSERVER_DEVELOPER and perform the layer creation action, the geoserver logs could provide more hints about where is the problem, and a stack trace if there is an exeception. Also provide complete context about what datastore are you using and the structure of your data.
You may also try updating to different versions and testing, to identify exactly which version the regression occurs in.
This is the general advice offered on the Upgrading GeoServer — GeoServer 2.28.0 User Manual page.
