Dear All,
I need to produce a scatterplot in lizmap using Dataviz.
I assigned as X value a decimal field and in Trace I selected a second decimal field.
The ouput graph shows the line instead of points. How can I produce points instead of lines?
Thanks
Pierluigi
Thanks
I just added a js file with this code:
lizMap.events.on({
'datavizplotloaded': (evt) => {
if( evt.id === 'dataviz_plot_1'){
Plotly.restyle( evt.id, {
mode: "markers"
And It worked.
Now If I would change some styles like colors marker or dimention even through the js file?
yes @pierluigiderosa you can totally customize the chart this way
