There is a login issue in Geoserver version 2.28.0 Unable to login but when clicked on Left Panel “About Geoserver“ the page is logging in. Please look into it.
Could you precise how you deploy GeoServer and which kind of Authentication are you using?
Have you upgraded to a more recent version ?
I use for several customer the 2.28.x serie for several weeks now and we don’t have this issue.
Have you looked to the log file ? If you have error messages in it, please share it if you want more help.
Alexandre
Geoserver war file is deployed in Wildfly 25.0.0 and java 21.0.2 2024-01-16 LTS
No I am using v2.28.0 There is no log file related to the same
Thanks for the details. I don’t work with Wildfly.
Do you mean you have no log file at all or no log related to the problem?
Alexandre
I think itz a confgiuration issue from nginx
Have you checked the Upgrade documentation:
and especially:
There was also a recent post discussing this issue, and asking the poster to update the documentation for others to benefit from the community input. Perhaps you could do it?
Peter
I have made changes in nginx configuration
location /geoserver/ {
access_log off;
proxy_pass http://127.0.0.1:8080/geoserver/;
proxy_redirect off;
proxy_set_header Host $host;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto https;
proxy_set_header X-Forwarded-Scheme https;
proxy_set_header X-Forwarded-Host $host;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection “upgrade”;
still no change
inside geoserver.war
PROXY_BASE_URL https://gis.xxx.in/geoserver
GEOSERVER_CSRF_WHITELIST gis.xxx.in<context-param>
<param-name>GEOSERVER_DATA_DIR</param-name>
<param-value>/data/geoserver_data</param-value>
</context-param>
Sending form data to ‘https://gis.xxx.in/geoserver/j_spring_security_check’ violates the following Content Security Policy directive: “form-action ‘self’”. The request has been blocked.
