looking for r.proj
I'm trying to find a compiled program called r.proj to change a raster
map from one projection to another. The raster map I have is in albers
equal area and I need it in utm. Does anyone have any suggestions.
Thanks Teresa Salyer <salyer@tiaer.tarleton.edu>
Teresa Salyer
TIAER
Tarleton State University
Teresa:
I wrote a script r.proj which you can find bundled up with a
Gmakefile, etc at
ftp://ftp.ned.dem.csiro.au/pub/r.proj.tar.gz
You need to have Gerry Evenden's PROJ software installed, and
also Darrell McCauley's s.sample. On the latter, however, we
have also enhanced s.sample to make improvements in the memory
management. This reduces the time to re-project some maps from
24 hours to a matter of minutes, so is strongly recommended.
Our s.sample can also be found at
ftp://ftp.ned.dem.csiro.au/pub/s.sample.tar.gz
The r.proj script has only been tested on mercator, simple conic,
and UTM (from memory ...) and will almost certainly need some
tinkering with for other projections. It all depends on the
argument list passed to the "proj" steps. There are normally
two calls to "proj" - one inverse, to get from your source
projection to lat-long, and then one forward to get from lat-long
to your target projection. You should inspect the code for
both of these steps.
Good luck Simon Cox
__________________________________________________
Dr Simon Cox - Australian Geodynamics Cooperative Research Centre
CSIRO Exploration & Mining, PO Box 437, Nedlands, WA 6009 Australia
T: +61 9 389 8421 F: +61 9 389 1906 simon@ned.dem.csiro.au
http://www.ned.dem.csiro.au/unrestricted/people/CoxSimon/
