Good day,
After reading the LT+ manual, it doesnt appear that it has auto raster line
following capability, i.e. each point must be digitizer entered. Can someone
verify this for me?
David Hyduke
dave@comsearch.digex.net
Good day,
verify this for me?
David Hyduke
In article <199405091404.KAA01768@comsearch.digex.net> you write:
Good day,
verify this for me?Thanks,
David Hyduke
I'm not 100% sure I understand your question however, LTPlus can accept
raster and vector input files. If vector is used it can be copied into the
raster image (which is where most work is done) using level_dup or
level_icopy. level_dup copies en mass, level_icopy copies only objects you
click on. It also has commands that help cleanup the rasterized data.
Dan Haskell
"Sire, plague and pestilence stalk the land like, er, two huge stalking things."
- Black Adder III
email: danh@teleport.com vox: (503) 257-9042
