If you are using the plotter command in MAPGEN, it has a -r option
which rotates the map 90 degrees
Linda Bragg lbragg@ncrdsr.usgs.er.gov
USGS
956 National Center
Reston, VA 22092
703-648-6451
GRASSuser's (MAPGENuser's?),
Still plugging along, we've got MAPGEN compiled, identified to our
system, and producing maps. We are using a HP 7475A, which handles 8 1/2
by 11" or 11" by 17" paper. My question is in ROTATING the image when using
the smaller paper.I can physically switch to the rotate function on the plotter, but
the function is over-ridden by the code coming from MAPGEN. Does anyone have
a work-around for this? It's something to do with the 'hpgl' language and the
"RO" command, I believe, I just don't know what to adjust.Any suggestions offered can be sent to me directly, as the info on
this particular plotter might not be of interest to the entire list.Thank you.
Ronald Thomas ^ ront@meeker.cfnr.colostate.edu
Natural Resources Spec. (GIS) ^
Resources Management Division ^ Phone: 303-586-3565 x285
Rocky Mountain National Park ^ 700-323-7285 (FTS)
Estes Park, CO 80517 ^
