TO: grassu-list
RE: BUG IN GRASS-MAPGEN INTERFACE'S make.mapdef SHELL SCRIPT
Ronald Thomas, National Park Service, USA, and Bernd Munier,
Roskilde Univ., have written here re: a failure in the make.mapdef
script in the GRASS-MAPGEN Interface. The error message is similar
to this:
.../mapgen/interface/make.mapdef: syntax error at line 125: 'end
of file' unexpected
Bernd says:
> In line 125, a if...then clause is executed and left improperly....
Technically I suppose this is true - the "if" statement is concluded
improperly there. But the real problem is at/near line 63:
if [ "$PARMS" = "" ]; then exit
This is the "if" statement that is missing a "fi" marker to
properly end it. When the script is run, the end of the
"if" statement is sought, but the end of the file is encountered
before it is found (that is why you see the cryptic "unexpected
end of file" message).
To fix, simply add a new line with "fi" on it:
fi
Scott Wade wade@zorro.cecer.army.mil
U. S. Army Construction Engineering Research Laboratories
Env. Compliance Division, Spatial Analysis & Systems Team
Champaign, Illinois
