mapgen
I am getting the following problem when compiling mapgen
using the gmake method:
*** Error code 2
make: Fatal error: Command failed for target '/j6/grass/grass4.1/sun4/
mapgen/points'
Current working directory /j6/grass/mapgen/mapgen/src
*** Error code 1
make: Fatal error: Command failed for target 'all'
Any ideas on what is causing this problem?
Thanks in advance,
Jim Nolan
jnolan@tec.army.mil
