mapmask
r.mapmask never made it into 4.0. Neither did d.digit. However,
if you get the updates to grass4.0 from the ftp site
(moon.cecer.army.mil), you will find two programs r.in.poly and
r.digit. r.digit allows users to create a raster map by drawing
polygons on the screen (i.e, it is the replacement for d.digit).
It gathers coordinates and passes the them to r.in.poly to create
the raster map so you need both. AND for r.in.poly to compile you
need the updates to the gis library (src/libes/gis).
|GRASS 3.x had a program called mapmask (I think that's the right name).
|It allowed users to draw polygons on a map layer and then make them the
|current mask.
|Is there an analogous program in GRASS 4.0? There is a reference to
|r.mapmask in the g.manual "list", but no manual page is available. If the
|program exists, I assume that it didn't compile along with the other
|GRASS code. Where does the code live?
|Thanks....
| Mike Camann
| camann@athena.cs.uga.edu
Michael Shapiro U.S. Army CERL
email: shapiro@zorro.cecer.army.mil Environmental Division
phone: (217) 373-7277 P.O. Box 9005
fax: (217) 373-7222 Champaign, Ill. 61826-9005
