Ok, makes sense. Perhaps we can put them in drive or something? Just
want to make sure people like me who dont have these fonts installed
can see the finished product.
On Fri, Jul 28, 2017 at 7:45 AM, Jody Garnett <jody.garnett@gmail.com> wrote:
It is more that the printable files are big given resolutions involved. If
we upload the samples people will print them and they will look bad.
On Fri, Jul 28, 2017 at 7:38 AM Jeffrey Johnson <ortelius@gmail.com> wrote:
It would be great if you could publish the PDFs alongside, but I would
be a little leery of repo bloat if we intend to change them regularly.
I wonder if someone really smart with SVG could pull in the background as a reference (so it would not change each time the text and graphics over top was changed?
I see that the three points we discussed
during foss4g-europe code sprint have already
been reflected in the updated brochure
a) Have a sub-section for our FOSS4G event
b) Removes names in the credits on page-8 and
only mention marketing committee
c) Attend to minor edits in the brochure
Thanks again.
Venka
On 7/28/2017 11:21 PM, Luca Delucchi wrote:
I updated the brochure SVG files with my and Astrid comment, I hope
you like the changes...
On Sat, Jul 29, 2017 at 5:10 PM, Jody Garnett <jody.garnett@gmail.com>
top was changed?
That's possible, we can replace the embedded image in the SVG XML by a file
path, i.e. replace something like this:
If you are using Inkscape, it will let you select between these two when
putting an external image into the document.
The problem is that some programs won't follow these links and simply not
show the image. Inkscape seems to handle some paths well and some not, but
it can handle the absolute paths with file:// and relative paths without
file:// as in the example above. SVG format definition says this can be
IRI, so I suppose it can be anything. An example, although in a different
context shows relative path to a local file.
Projects will need to complete incubation to increase their visibility at
OSGeo. OSGeo Live made the change last month.
Incubation is an important process in our foundation and projects
undergoing incubation process need to be appropriately recognized
as such.
It is also important to distinguish graduated projets, projects
that are in incubation and community projects that fall under
either of the categories.
So, I think it is better to continue with our past practice and
have a logo for "OSGeo Project in incubation".
Best
Venka
Jody Garnett
On 30 July 2017 at 20:36, Venkatesh Raghavan <venka.osgeo@gmail.com> wrote:
Dear All,
Do we have a new logo for "OSGeo Project in Incubation".
Best
Venka
as such.
Best
Venka
Jody Garnett
Dear All,
Best
Venka
Hi everyone,
I would like to support the request from Venka.
Projects are doing the best they can to provide the requested informations to complete the incubation. Sometimes it also happen that we are at some weeks of the validation but it finally never occurs because of one reason or another. Sometimes, it is not directly linked to the project.
So I don’t see any reason to blame or downgrade the projects that are trying to complete their incubation.
I don’t think we should feel bad that some project take long time to incubate as it does not depend only on the project itself but also on the mentor dedication and availability. This may vary over the time and the two are not always in sync.
as such.
Best
Venka
Jody Garnett
Dear All,
Best
Venka
Venka we can have this discussion on the incubation list - it is part of
the larger what are we doing with projects discussion.
I think this discussion has to be on the board-list.
I see no need to promote these projects for work they are not performing.
I strongly disagree with the statement above.
a) What do you mean by "not performing". Is the a the yardstick
for measuring such non-performance? OTB which was in incubation has
graduated recently, and I see at least few projects in incubation
that are very active and perhaps on the verge of graduation too.
b) I think we should not confuse between projects included in
OSGeo-Live and projects being incubated in OSGeo.
c) I see the need to attract more and more projects to incubate
in OSGeo and give them necessary visibility as "OSGeo Project in incubation"
Venka
as such.
Best
Venka
Jody Garnett
wrote:
Dear All,
Best
Venka
We can make it part of the larger what are we doing with projects strategy for Boston f2f. Were you able to ask maxi & jeffm to report their findings to the board?
a) What do you mean by “not performing”. Is the a the yardstick
in OSGeo and give them necessary visibility as “OSGeo Project in incubation”
as such.
have a logo for “OSGeo Project in incubation”.
This thread is now very far afield from the original subject ... But I
second Gerald's comments here. Sometimes it just takes a final push to
get things over the line, and 'downgrading' them or something similar
would just become a stumbling block to that. We should endeavor to
find out why projects are taking so long and offer help, not penalize
them.
to the board?
Jody Garnett
incubation"
Venka
at
as such.
Best
Venka
Jody Garnett
wrote:
Dear All,
Best
Venka
Daniel this is not a (really not) a case of blame; but it is a case of transparency and communication.
It is a case of promoting appropriately - we have introduced a new thing, community projects, that better reflect where incubation projects are in the process. We are promoting community projects, including those that are in incubation as part of OSGeo.
Just because we are pulling additional projects (like geowebcache and pgrouting) into OSGeo does not automatically mean we are downgrading our projects that have committed to incubation.
I also think, that incubation takes often too long.
But it wouldn’t be fair to blame only the project or the mentors.
Sometimes it even takes weeks until the votes are collected to pass incubation
Pretty much everyone involved is doing it as volunteer and I think, that it just needs some push/reminder from time to time to both, mentors and projects, to continue the process.
Deadlines/milestones help to remember tasks. For example OSGeo Live releases are pushing my project every year to review documents and get things done before some deadlines.
The incubation commitee could for example require a status report every 4 or 6 months at specific dates.
It will probably help to get mentors and projects in sync and remind them, that there is something to do.
as such.
