Iván,
That would be great, thanks.
Yes, I meant the OSGeo instance of the tool. Most of the survey tools are
fairly similar. I might have even tooled around with LimeSurvey,
specifically, in the past.
If you could let me know when I have an account set up, I would appreciate
it.
Thanks for your speedy response,
Scott.
-----Original Message-----
Sent: Tuesday, April 9, 2024 3:47 PM
To: Scott McHale <scott.mchale@shaw.ca>
Cc: cro@osgeo.org; marketing@lists.osgeo.org
Subject: Re: Lime Survey question
El martes, 9 de abril de 2024 22:25:06 (CEST) Scott McHale escribió:
[...] I'm interested to understand whether the OSGeo Lime Survey tool
might be the right tool for gathering some information [...] help me
understand how I might use the tool [...]
Hi Scott, current CRO here.
So LimeSurvey is a generic tool for surveys, and the OSGeo SAC set up an
instance for us. I guess you've gathered that it's a similar tool to
surveymonkey / google forms / etc (or, check out https://en.wikipedia.org/
wiki/Comparison_of_survey_software )
I can try and set you up with an account there (which should be using your
LDAP credentials), so you can play around with it, create a couple of dummy
surveys, that kind of thing. Does that sound like something you'd like?
Best,
Iván Sánchez Ortega <ivan@sanchezortega.es> https://ivan.sanchezortega.es
