That is great, I placed some background images (provided as drafts from the designer) in github to help Helena make an html template. But if you are good with your template skills you should be able to do a much better job. Do you think if we make a PNG image with transparency you could layer it overtop of a user supplied image?
For questions about the directory layout - we should have this conversation on the marketing email list, if you do not mind joining me there? (Kind of wish we could rebrand the marketing committee as “outreach committee” to attract volunteers like yourself).
Aside:
- Had to look up what reveal.js is, I assume you mean this one - http://lab.hakim.se/reveal-js/#/
- I usually use “landslide” (https://github.com/adamzap/landslide) and RST for presentations because I use RST for documentation
On 14 July 2017 at 09:09, Vaclav Petras <wenzeslaus@gmail.com> wrote:
Hi Jody,
I’m working on template for OSGeo presentation in Reveal.js. which directory layout you suggest? I’ve already forked the repository. I also plan to create Beamer one.
Vaclav (Vashek)
Jody Garnett
