I suggest once reviewed and approved in our next meeting we move the
material onto the main website.
To go along with these examples I have a few additional recommendations:
- Add additional examples be added to the main Trademark FAQ.(See above)
- The Link to Trademark and Trademark FAQ be made more obvious. (Any
ideas, I got there from searching the wiki)
- Styling be used to clearly highlight the examples in text and NOT be
used instead of not.
- Also possibly accompanied by a giant green checkmark or a big red
circle cross out for good/bad.
We actually have fairly good material on the subject, so I guess people
just aren't finding it or need more examples.
Alex,
Had a quick skim over the document and think you have done a good job.
Couple of comments:
* Under "Service Providers"
You start with "OSGeo Sponsors ..." which I suspect you mean to say "OSGeo Service Providers ..."
* Under OSGeo Chapter
I suggest changing the following:
"Chapters may either display their own logo alongside the OSGeo logo and/or use a slightly modified version of the OSGeo logo."
to
"Chapters may display their own logo and/or the OSGeo logo. Chapter logos can be a modified version of the OSGeo logo."
Alex,
Couple of comments:
Thanks for catching that, a little too much copy/paste going on last night.
to
Actually I meant what I said. Since the decision is still out, we never
reached a conclusion in the marketing committee, and possibly requires
the board to nod in approval, I was erring on the cautious side which is
that sure it's ok to modify the OSGeo logo if you are a chapter but you
also should show the regular OSGeo logo with it. To me this is the only
way to really play it safe under Trademark laws, and to be clear when a
Chapter is recognized by OSGeo and demonstrate it's relationship to OSGeo.
You can see from the language I chose, that I'm discouraging, but not
banning the use of a highly modified OSGeo logo without also putting the
regular osgeo logo on the page. The wiki page you mentioned actually
meets this recommendation, as the OSGeo logo is in the upper left of the
page.
Note: Copyright isn't an issue because we can easily do a CC-NC but
Trademark is a whole different game. There's also the question of Brand
dilution.
Alex
On 23/11/10 15:04, Alex Mandel wrote:
> From our last couple of meeting agendas I've attempted to clarify some
of the Trademark questions that have some up.
> to
> > Note that some chapters have modified the OSGeo-Logo image. Eg Aust-NZ:
> http://wiki.osgeo.org/wiki/Aust-NZ
page.
dilution.
I think it inappropriate to mandate that a local chapter logo can only be used if the OSGeo logo is used at the same time, primarily because volunteers will use the logo without reading what the logo guidelines are. And volunteers will likely write a letter to their local council with the local chapter logo on the letter head, (and will forget to use the OSGeo logo) and that should be ok.
