Is there a documented procedure available to change the red square points into MIL-STD-2525 symbols?
there is no documentation as GeoServer does not support out of the box MIL-STD-2525 symbology.
However, a java library is available to generate the symbols, so it should be possible, with some coding, to hook it up to GeoServer. That would be a nice addition.
If you are interested in such an implementation, have a look at this guide:
Hope this helps
