Good morning all,
Well I managed to get Grass5.0beta3 to build under Irix 6.5.2, but I
have yet to find out if it actually works!
There seems to be a major problem with the keyboard mapping. I can't get
Grass started, because it doesn't know that I have hit the escape key
after entering the location, mapset and database in the startup screen.
The escape key is not the only one which gives trouble
Hi Terry,
due to cursor key support there was a change:
If you want to leave a text screen, press
<ESC><ENTER> instead of just <ESC> (as it was in GRASS 4.x)
One must be very careful with text entry as there is no delete or
backspace working either.
No, but you can use the cursor keys now (arrow left = backspace)
Hope this helps
Markus Neteler
