Need assistance with sed for script
Hi there,
currently I am writing a small installation script
for the GRASS 5 binary packages. It is nearly
complete, but I struggle with "sed" command.
I need a variable to be expanded within a sed call.
The following is *not* working:
#!/bin/sh
# GRASS 5 binary package installation tool
#... [cut]
PATH=/home/mypath
sed "s/\/usr\/local\/grass\-5.0b/${PATH}/g" $PATH/etc/monitorcap.orig > \
Idea is to change the paths within monitorcap to
user's preference automatically.
Any help is appreciated, thank you in advance
  Markus Neteler
[Posted and mailed]
Shell programming and especially the antique quoting rules of
the bourne shell (inherited to csh, bash and all them) are though.
((Would be so nice if people would use "es" or "python" for this
kind of work, but both cannot resonably be demanded as prerequisites on
all machines.))
#!/bin/sh
#... [cut]
PATH=/home/mypath
Analysis:
First you change your PATH. How do you find sed?
Secondly you got additional slashes in your variable which sed cannot
digest.
Solution: use sed's magic substitute seperator
Look at my attached example.
  Bernhard
Research Assistant, Geog Dept UM-Milwaukee, USA. (www.uwm.edu/~bernhard)
(attachments)
probe (449 Bytes)
