I’ve just noticed the GeoServer nightly builds has been broken since June 9th.
The community modules build breaks on ElasticSearch, but in an odd way:
- Full log
- Relevant bit exerpt:
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.10.1:testCompile (default-testCompile) on project gs-web-elasticsearch: Compilation failure: Compilation failure:
[ERROR] /var/lib/jenkins/workspace/geoserver-main-nightly/src/community/elasticsearch/src/test/java/org/geoserver/elasticsearch/ElasticTestSupport.java:[26,32] package org.elasticsearch.client does not exist
[ERROR] /var/lib/jenkins/workspace/geoserver-main-nightly/src/community/elasticsearch/src/test/java/org/geoserver/elasticsearch/RestElasticClient.java:[30,32] package org.elasticsearch.client does not exist
[ERROR] /var/lib/jenkins/workspace/geoserver-main-nightly/src/community/elasticsearch/src/test/java/org/geoserver/elasticsearch/RestElasticClient.java:[31,32] package org.elasticsearch.client does not exist
[ERROR] /var/lib/jenkins/workspace/geoserver-main-nightly/src/community/elasticsearch/src/test/java/org/geoserver/elasticsearch/RestElasticClient.java:[32,32] package org.elasticsearch.client does not exist
[ERROR] /var/lib/jenkins/workspace/geoserver-main-nightly/src/community/elasticsearch/src/test/java/org/geoserver/elasticsearch/RestElasticClient.java:[33,32] package org.elasticsearch.client does not exist
[ERROR] /var/lib/jenkins/workspace/geoserver-main-nightly/src/community/elasticsearch/src/test/java/org/geoserver/elasticsearch/RestElasticClient.java:[34,32] package org.elasticsearch.client does not exist
[ERROR] /var/lib/jenkins/workspace/geoserver-main-nightly/src/community/elasticsearch/src/test/java/org/geoserver/elasticsearch/RestElasticClient.java:[52,19] error: cannot find symbol
[ERROR] private final RestClient client;
[ERROR] ^
[ERROR] symbol: class RestClient
[ERROR] location: class org.geoserver.elasticsearch.RestElasticClient
[ERROR] /var/lib/jenkins/workspace/geoserver-main-nightly/src/community/elasticsearch/src/test/java/org/geoserver/elasticsearch/RestElasticClient.java:[54,19] cannot find symbol
[ERROR] /var/lib/jenkins/workspace/geoserver-main-nightly/src/community/elasticsearch/src/test/java/org/geoserver/elasticsearch/RestElasticClient.java:[64,30] cannot find symbol
[ERROR] /var/lib/jenkins/workspace/geoserver-main-nightly/src/community/elasticsearch/src/test/java/org/geoserver/elasticsearch/RestElasticClient.java:[68,30] cannot find symbol
[ERROR] /var/lib/jenkins/workspace/geoserver-main-nightly/src/community/elasticsearch/src/test/java/org/geoserver/elasticsearch/RestElasticClient.java:[68,49] cannot find symbol
[ERROR] /var/lib/jenkins/workspace/geoserver-main-nightly/src/community/elasticsearch/src/test/java/org/geoserver/elasticsearch/RestElasticClient.java:[243,13] cannot find symbol
[ERROR] symbol: class Response
[ERROR] /var/lib/jenkins/workspace/geoserver-main-nightly/src/community/elasticsearch/src/test/java/org/geoserver/elasticsearch/RestElasticClient.java:[292,5] cannot find symbol
[ERROR] /var/lib/jenkins/workspace/geoserver-main-nightly/src/community/elasticsearch/src/test/java/org/geoserver/elasticsearch/RestElasticClient.java:[296,49] cannot find symbol
[ERROR] → [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] MojoFailureException - Apache Maven - Apache Software Foundation
[ERROR]
[ERROR] mvn -rf :gs-web-elasticsearch
Took me a while to figure out… the failure seemed related to the BOM landing (landed same date, no other changes in gt-elasticsearch that day), but I could not reproduce it… after much fiddling locally and on the build server, I’ve found the nightly communityBuild was running with -nsu and I’m guessing that prevented some BOM related update to be gathered?
Removed it, and the nightly is now back in business.
Anrea
