OGC API Features layer from GeoServer, not opening in QGIS
We are running GeoServer 2.27.1 and have added OGC API Feature extension.
The page looks ok: https://paituli.csc.fi/geoserver/ogc/features/v1
But QGIS only manages to get the list of layers. Layer listing is for some reason only very slow.
Adding any layer to the map results in:
Layer data source could not be found.
It seems that QGIS tries to guess API version and makes a request to:
https://paituli-test.csc.fi/geoserver/ogc/features/v1/openapi?f=application%2Fvnd.oai.openapi%2Bjson%3Bversion%3D3.0
But that does not give any reasonable reply.
https://paituli-test.csc.fi/geoserver/ogc/features/v1/openapi is already broken.
I wonder if we have some settings off in our installation or is it some more general problem? Or if somebody would know some workaround for this.
I tried also 2.28.1. There error message to openapi call is different, but it does not work neither.
With GDAL command-line it gives error about openapi, but then continues to get the data.
ogrinfo OAPIF:``https://paituli.csc.fi/geoserver/ogc/features/v1/`` paituli:tike_vaki1km_2024 -fid 1
INFO: Open of OAPIF:https://paituli.csc.fi/geoserver/ogc/features/v1/' using driver OAPIF’ successful.
ERROR 1: HTTP error code : 500
ERROR 1: HTTP error code : 500, {“code”:“NoApplicableCode”,“description”:“java.lang.NullPointerException”}
(Continued by normal output.)
With 2.28.1 the error code is different:
ERROR 1: HTTP error code : 500, {“code”:“NoApplicableCode”,“description”:“Could not find path item /collections/{collectionId}/tiles/{tileMatrixSetId}/{tileMatrix}/{tileRow}/{tileCol}”}
The same layers work via WFS.
Kylli Ek
Hi Kylli,
I made also a quick test with GDAL
ogrinfo oapif:"https://paituli.csc.fi/geoserver/ogc/features/v1/" --debug on --config cpl_curl_verbose=yes
The landing page is read from
https://paituli.csc.fi/geoserver/ogc/features/v1/?f=application%2Fjson
Landing page has a link for
“API definition for this endpoint as application/vnd.oai.openapi+json;version=3.0”
https://paituli.csc.fi/geoserver/ogc/features/v1/openapi?f=application%2Fvnd.oai.openapi%2Bjson%3Bversion%3D3.0
but that link yields an error
‘Cannot invoke “org.geoserver.config.ServiceInfo.getGeoServer()” because “service” is null’
GDAL still continues and sends a request
https://paituli.csc.fi/geoserver/ogc/features/v1/collections/paituli:dvv_osoitteet_na_2016_shape_euref/items?f=application%2Fgeo%2Bjson&limit=20
That is awfully slow. Maybe Geoserver reads all the 5 million addresses first before sending the 20 first addresses out?
Then GDAL wants to read the schema and it takes it from the WFS
https://paituli.csc.fi/geoserver/wfs?version=2.0&service=WFS&typenames=paituli%3Advv_osoitteet_na_2018_shape_euref&request=DescribeFeatureType)
GDAL wants to do the same things for all the layers. Every now and then your server hits a timeout with a message " Requested timeout out while waiting to be executed, please lower your request rate.
The server is currently unable to handle the request due to a temporary overload or scheduled maintenance, which will likely be alleviated after some delay."
Perhaps the service works but it is unusable slow even when the timeout is not hit.
I suggest making a test service with just one collection. Try to make is fast first, and add more collections later.
-Jukka Rahkonen-
It seems that the problem is “fixed” with removing ogcapi-images-plugin and ogcapi-tiled-features-plugin from the installation.
Then the openapi page works for OGC features and so QGIS gets the data
