OIDC won't accept namespaced claims for role mapping key with Id Token role source
I’m using auth0 as IDP and tried to use namespaced claim for JSON path. It works non-namespaced claim eg. geoserver_roles but not namespaced claim eg. http://example.com/user_roles
Could you modify code to here (row 45) to support both?
Auth0 recommends to use namespace claims for custom claims:
You can make a PR to do this, then one of the volunteers will try to find time to look at it. This is open source so there’s no you in the chain.
Ian
Ian Turton
