#3040: upgrade woodpecker-ci
Reporter: strk | Owner: robe
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: SysAdmin/Woodie | Keywords:
The version we are running is affected by a bug which results in pipelines
hitting a disk quota when multi-step configurations are used, for example
here: Woodpecker
An enhancement was included in version 2.0 which should avoid this
problem, see: https://github.com/woodpecker-ci/woodpecker/pull/2681
By upgrading (I think it's the agents that need this, but we could upgrade
all) we should be fixing this problem
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3040>
OSGeo <Gter - OSGeo;
Component: SysAdmin/Woodie | Resolution:
Keywords: |
Comment (by strk):
Downstream issue for postgis: https://trac.osgeo.org/postgis/ticket/5637
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3040#comment:1>
OSGeo <https://osgeo.org/>
Priority: normal | Milestone: Sysadmin Contract 2024-I
Keywords: |
Changes (by robe):
* milestone: Unplanned => Sysadmin Contract 2024-I
Ticket URL: <#3040 (upgrade woodpecker-ci) – OSGeo;
Keywords: |
Comment (by robe):
Going to start the upgrade process to the 2.0 series.
Type: task | Status: closed
Component: SysAdmin/Woodie | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
done but still some loose ends in postgis and I think I have osgeo8
woodie-client to upgrade to latest woodie agent but waiting off since it
seems to run fine against the woodie-server and the new agent seems to be
quirky.
