[OSGeo] #3070: GFOSS.it discourse category
Reporter: lucadelu | Owner: sac@…
     Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: SysAdmin | Keywords:
We would like to move three [http://lists.gfoss.it/mailman/listinfo
Italian mailing lists] to the new Discourse OSGeo instance.
The candidates are:
- [Pagina di informazioni della lista Gfoss GFOSS.it] public
- [Pagina di informazioni della lista Consiglio Consiglio]
this is private for the association board and could be named GFOSS.it-
board
- [Pagina di informazioni della lista Soci.gfoss Soci GFOSS]
this is privare for the association members and could be named GFOSS.it-
members
About the new names I need confirmation from actual board
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3070&gt;
OSGeo <Gter - OSGeo;
Component: SysAdmin | Resolution:
Keywords: |
Comment (by cvvergara):
Please send me the mbox directories/files
Ticket URL: <#3070 (GFOSS.it discourse category) – OSGeo;
Component: SysAdmin/Discourse | Resolution:
Keywords: |
Changes (by strk):
* component: SysAdmin => SysAdmin/Discourse
Keywords: |
Files have been received, will proceed to test on staging
Keywords: |
Test on staging
Loaded gfoss:
* Done (02h 23min 24sec)
* gfoss - OSGeo Discourse
Loaded opendata into gfoss
* example message https://discourse.staging.osgeo.org/t/opendata-geodati-
nc/19651
Loaded archeologia
* archeologia - OSGeo Discourse
Loaded private mbox foss4g2022
* https://discourse.staging.osgeo.org/c/foss4g2022/24
* Category was created first
Note:
I recommend to create the categories & groups before uploading to
production.
That will allow to organize categories.
* Discourse Nesting limit 1 level under root.
Keywords: |
[1] lists.gfoss.it Mailing Lists
The following are private:
* consiglio
* foss4g2022
* gfoss-day
* soci.gfoss
mailman is empty
Non empty and public:
* archeologia (last used on february 2016)
* comitato-scientifico (not in [1], probably was disabled, but the
archives are not reachable via http://lists.gfoss.it/pipermail/comitato-
scientifico/)
* gfoss
* gfoss-day-cs (last used on october 2014)
* opendata (last used on october 2011)
Reporter: lucadelu | Owner: cvvergara
Priority: normal | Milestone: Sysadmin Contract 2024-II
Keywords: |
Changes (by robe):
* owner: sac@… => cvvergara
* milestone: Unplanned => Sysadmin Contract 2024-II
Keywords: |
Changes (by cvvergara):
* milestone: Sysadmin Contract 2024-II => Unplanned
Comment:
@lucadelu
Please write in the ticket:
* which lists to migrate:
* if you would like to merge into gfoss the unused mailing lists:
archeologia, comitato-scientifico gfoss-day-cs opendata
* If gfoss (or which ones) is going to be a mirror
* If you also want to have the move/mirror ones
Note that the lists can change names for example:
archeologia
can be
archeologia-it
Keywords: |
Comment (by lucadelu):
@ccvergara thanks a lot for your work, I'm going to update the GFOSS board
and I'll be back to you as soon as possible with answers to your
questions.
Keywords: |
@ccvergara so we would like to have
* exclude from any operation: foss4g2022, gfoss-day, gfoss-day-cs,
comitato-scientifico. These are not useful anymore
* gfoss public with archeologia and opendata merged
* soci.gfoss and consiglio as private category
None of them should be mirror since we are going to shut down the old
server.
Should I do anything ?
Keywords: |
Q:
For
"soci.gfoss and consiglio as private category"
you mean
- one category for both (merged)
- one category each?
Keywords: |
Comment (by strk):
The link in comment:4 qgis-it-user - OSGeo Discourse takes
me to qgis-it - where is the gfoss category ? Did it move ?
Keywords: |
Comment (by strk):
Found the correct link: GFOSS.it - OSGeo Discourse
     Type: task | Status: closed
Component: SysAdmin/Discourse | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Going to close this out, assume you are set.
Keywords: |
