#3141: Upgrade Discourse to latest 3.2.0beta5 version
Reporter: robe | Owner: sac-tickets@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2024-I
Component: SysAdmin/Discourse | Keywords:
Just saw in admin panel, showing
"A critical update is available. Please upgrade!"
I'm going to test on staging first to make sure it doesn't break anything
before attempting on production.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3141>
OSGeo <Gter - OSGeo;
Component: SysAdmin/Discourse | Resolution:
Keywords: |
Comment (by cvvergara):
Last time what broke was the mbox importing.
The upgrade had to be done manually instead of using the admin panel
Ticket URL: <#3141 (Upgrade Discourse to latest 3.2.0beta5 version) – OSGeo;
Keywords: |
Comment (by robe):
@cvvergara,
Can you check if the mbox importing is still working on staging? I did
the upgrade thru the interface on staging. If import still works, then I
think we should be good to just use the web interface and not incur any
downtime as is required doing via the OS.
Keywords: |
Comment (by robe):
BTW looks like it upgraded staging to 3.3.0.beta1-dev.
Keywords: |
Import fails after the admin panel upgrade
<internal:/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/core_ext/kernel_require.rb>:38:in
`require': cannot load such file -- sqlite3 (LoadError)
from
`require'
from
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/bootsnap-1.18.3/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:17:in
`require'
from
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.6.13/lib/zeitwerk/kernel.rb:34:in
`require'
from
/var/www/discourse/script/import_scripts/mbox/support/database.rb:3:in
`<main>'
from
/var/www/discourse/script/import_scripts/mbox/importer.rb:4:in
`require_relative'
from
/var/www/discourse/script/import_scripts/mbox/importer.rb:4:in `<top
(required)>'
from script/import_scripts/mbox.rb:12:in `require_relative'
from script/import_scripts/mbox.rb:12:in `<module:Mbox>'
from script/import_scripts/mbox.rb:11:in `<module:ImportScripts>'
from script/import_scripts/mbox.rb:10:in `<main>'
#3141: Upgrade Discourse to latest 3.3.0.beta1 version
Keywords: |
Changes (by robe):
* summary: Upgrade Discourse to latest 3.2.0beta5 version => Upgrade
Ticket URL: <#3141 (Upgrade Discourse to latest 3.3.0.beta1 version) – OSGeo;
Keywords: |
Comment (by robe):
I'll do a test on staging with a full shutdown and then if looks okay do
the same on production. I'm upgrading the docker plugin at moment on
both.
Type: task | Status: closed
Component: SysAdmin/Discourse | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Done on both staging and production
