#3160: repo entry for netcdf/4.0.patch broken: misses the jar file
Reporter: bernhard | Owner: sac-tickets@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: SysAdmin | Keywords:
A jar file is missing from the repo, which breaks build of
old tags and links from outside.
Suggested solution:
adding of the jar file (from a backup or somebody's cache).
Index of /edu/ucar/netcdf/4.0.patch
as of today
has the following files:
netcdf-4.0.patch.jar.md5 Fri Aug 06 21:39:07 GMT 2021 32
netcdf-4.0.patch.jar.sha1 Fri Aug 06 21:37:56 GMT 2021 40
netcdf-4.0.patch.pom Fri Aug 06 21:39:08 GMT 2021 190
netcdf-4.0.patch.pom.md5 Fri Aug 06 21:39:08 GMT 2021 32
netcdf-4.0.patch.pom.sha1 Fri Aug 06 21:39:09 GMT 2021 40
so
is missing.
So when trying to build e.g. the old 3.6.x from Geonetwork the build
fails. Even though netcdf-4.0.patch is outdated (just like this version of
Geonetwork using it) keeping the file around for being able to reproduce
old builds and thus reason about changes is useful.
External links are broken like the link to the jar file from
https://mvnrepository.com/artifact/edu.ucar/netcdf/4.0.patch
The file in question is not available from upstream anymore, so it would
need to be located. Some users have it in their cache. (I know someone has
but the person is unavailable for another week.)
Wild guess: the assumed corruption of the repos mentioned at #3116 may
have also let to this file missing.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3160>
OSGeo <Gter - OSGeo;
