#3260: Add CNAME for gdal.org
Reporter: dbaston | Owner: sac-tickets@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: SysAdmin/DNS | Keywords:
GDAL will be migrating its documentation to ReadTheDocs
([gdal-dev] Motion: Migrate gdal.org to ReadTheDocs)
Please add a CNAME for gdal.org pointing to {{{readthedocs.io}}}.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3260>
OSGeo <Gter - OSGeo;
Priority: normal | Milestone: Sysadmin Contract 2024-I
Component: SysAdmin/DNS | Resolution:
Keywords: |
Changes (by robe):
* milestone: Unplanned => Sysadmin Contract 2024-I
Comment:
done. But I'm getting some error with unsupported protocol cloudflare
error.
Ticket URL: <#3260 (Add CNAME for gdal.org) – OSGeo;
Type: task | Status: closed
Component: SysAdmin/DNS | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Just a note the error I am getting is from cloudflare which I assume is
what readthedocs.io is using.
You've requested a page on a website (gdal.org) that is on the Cloudflare
network. Cloudflare is currently unable to resolve your requested domain
(gdal.org). There are two potential causes of this:
Most likely: if the owner just signed up for Cloudflare it can take a few
minutes for the website's information to be distributed to our global
network.
Less likely: something is wrong with this site's configuration. Usually
this happens when accounts have been signed up with a partner organization
(e.g., a hosting provider) and the provider's DNS fails.
I assume that means you need to do something in readthedocs.io to register
gdal.org or whatever you registered just hasn't propagated yet.
Anyway I'm going to close this out feel free to reopen if you still have
issues after a couple of hours or you make config changes on your end.
Keywords: |
Comment (by dbaston):
Everything is working fine as far as I can tell. Thanks!
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3260#comment:3>
