[OSGeo] #3350: Hosting for the (upcoming) CRO support system
Reporter: Lads | Owner: sac-tickets@…
     Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: SysAdmin | Keywords:
Dear all,
today I presented to the Board a proposal to develop a new information
system to support the OSGeo Elections [0], obtaining approval [1].
To get things going the following hosting resources are necessary:
1. A code repository (short term).
2. Application hosting for a data-base plus web interface (medium term).
This application is meant to be used only the CRO(s) and thus not
available to the general public.
Thank you.
[0] [Board] CRO support system next meeting
[1] Approve new CRO support system
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3350&gt;
OSGeo <Gter - OSGeo;
Component: SysAdmin | Resolution:
Keywords: |
Comment (by robe):
You have any ideas on any specs you need.
For code repository, I think you can just create an org on gitea and add a
repo -- https://git.osgeo.osg/gitea or add it under the osgeo org
Let us know if you have questions or need permissions.
For application hosting, you have any ideas on what you need here? specs
of server, database, application(s) you will be using?
Ticket URL: <#3350 (Hosting for the (upcoming) CRO support system) – OSGeo;
Keywords: |
Comment (by cvvergara):
- Set up a VM running ubuntu noble 24.04 with:
   - docker?
- Set up a repository for CRO: elections
- sudo right to CRO members & helpers in order to do installation of
required software, development and maintenance
   - ivansanchez
   - lads
   - cvvergara
   - msmitherdc
- Domain cro.osgeo.org (with a Work in progress)
Keywords: |
Repository created: https://git.osgeo.org/gitea/osgeo/elections
Group created: Sign In - OSGeo Git Services: Gitea - Git with a cup of tea
Keywords: |
- Members added to shell group and have sudo rights
Keywords: |
Members need to add their ssh key
Keywords: |
Leaving about the domain for another ticket when we actually start needing
it
     Type: task | Status: closed
Priority: normal | Milestone: Sysadmin Contract 2025-II (vicky)
Component: SysAdmin | Resolution: fixed
Keywords: |
Changes (by cvvergara):
* milestone: Unplanned => Sysadmin Contract 2025-II (vicky)
* resolution: => fixed
* status: new => closed
Keywords: |
Motion:
