[OSGeo] #3361: Website 2016.foss4g.org vs foss4g2016.org
Reporter: joto | Owner: jive
     Type: defect | Status: new
Priority: normal | Milestone: Unplanned
Component: WebSite | Keywords:
I am from FOSSGIS, the local chapter in Germany that organized FOSS4G
2016. If I see that correctly there are two copies of the website for that
event: 2016.foss4g.org hosted by OSGeo and foss4g2016.org hosted by us.
That doesn't make much sense.
We should probably change our copy into a redirect to the canonical name
2016.foss4g.org if that is okay with you and if there are no dependencies
on the OSGeo side to our website. Does that make sense?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3361&gt;
OSGeo <Gter - OSGeo;
     Type: defect | Status: closed
Component: WebSite | Resolution: fixed
Keywords: |
Changes (by robe):
* resolution: => fixed
* status: new => closed
Comment:
Yes that makes sense and probably safer since foss4g2016.org is a root
domain which will always require repurchase to keep alive.
Let us know if you need anything from us to make that happen.
Ticket URL: <#3361 (Website 2016.foss4g.org vs foss4g2016.org) – OSGeo;
