#3363: Create grassbot user on 'osgeo8-grass' and 'osgeo7-download'
Reporter: neteler | Owner: sac-tickets@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: SysAdmin | Keywords: LDAP,ssh
For automated artifact upload we would need a "grassbot" user on the
'osgeo8-grass' and 'osgeo7-download' machines.
This user has already been generated in OSGeo-LDAP.
We then want be able to login via ssh or copy artifact via scp.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3363>
OSGeo <Gter - OSGeo;
Component: SysAdmin | Resolution:
Keywords: LDAP,ssh |
Comment (by robe):
You need to login as that grassbot user and then add the ssh public key to
that account.
That should allow you to push to osgeo7-download with ssh key.
For the osgeo8-grass, that one doesn't pull ssh pubkey from LDAP, so would
need you to login as that user and register the pub key under that
account.
Ticket URL: <#3363 (Create grassbot user on 'osgeo8-grass' and 'osgeo7-download') – OSGeo;
Comment (by neteler):
I tried, to no avail:
Using the ssh config stated here:
SAC Service Status - OSGeo
Re: "download", I am not authorized:
ssh -v -v grassbot@osgeo7-download
OpenSSH_9.6p1, OpenSSL 3.2.4 11 Feb 2025
debug1: Reading configuration data /home/mneteler/.ssh/config
debug1: /home/mneteler/.ssh/config line 24: Applying options for osgeo7-*
debug1: /home/mneteler/.ssh/config line 93: Applying options for *
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: Reading configuration data /etc/ssh/ssh_config.d/50-redhat.conf
debug2: checking match for 'final all' host osgeo7-download originally
osgeo7-download
debug2: match not found
debug1: Reading configuration data /etc/crypto-policies/back-
ends/openssh.config
debug1: configuration requests final Match pass
debug1: re-parsing configuration
debug2: add_identity_file: ignoring duplicate key ~/.ssh/grassbot_osgeo
osgeo7-download
debug2: match found
ends/openssh.config
debug1: Executing proxy command: exec ssh grassbot@hop.osgeo7.osgeo.org -W
$(sed -e "s/^osgeo7-//;s/$/.lxd/" <<< "osgeo7-download"):22
debug1: identity file /home/mneteler/.ssh/grassbot_osgeo type 3
debug1: identity file /home/mneteler/.ssh/grassbot_osgeo-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_9.6
grassbot@hop.osgeo7.osgeo.org: Permission denied (publickey).
kex_exchange_identification: Connection closed by remote host
Connection closed by UNKNOWN port 65535
although the ssh pub key is in the LDAP profile.
Re: "grass.osgeo.org":
mneteler@caddy: ~$ ssh grasslxd
Enter passphrase for key '/home/mneteler/.ssh/id_ed25519':
Linux grass 5.15...
neteler@grasslxd:~$ cd ..
neteler@grasslxd:/home$ ls
cmbarton/ darkblueb/ martinl/ neteler/ robe/ strk/ tmsz/
There is no user "grassbot", shall I generate it?
Comment (by robe):
Replying to [comment:2 neteler]:
osgeo7-download is the same as upload.osgeo.org and the same as
hop.osgeo7.osgeo.org so that extra call to osgeo7-download is redundant.
Does ssh grassbot@upload.osgeo.org work?
if it does, just use that. That is all you need to upload files to
download.osgeo.org
> Linux grass 5.15...
Yes you should create a grassbot user and add the ssh pubkey of grassbot
to that account.
Just one observation: on "download" there is no user "grassbot", so maybe
that's why?
Or is that autogenerated somehow?
I have no success with upload.osgeo.org:
ssh -v grassbot@upload.osgeo.org
ends/openssh.config
ends/openssh.config
debug1: Connecting to upload.osgeo.org [140.211.15.30] port 22.
debug1: Connection established.
debug1: Authenticating to upload.osgeo.org:22 as 'grassbot'
debug1: load_hostkeys: fopen /home/mneteler/.ssh/known_hosts2: No such
file or directory
debug1: load_hostkeys: fopen /etc/ssh/ssh_known_hosts: No such file or
directory
debug1: load_hostkeys: fopen /etc/ssh/ssh_known_hosts2: No such file or
directory
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: algorithm: curve25519-sha256
debug1: kex: host key algorithm: ecdsa-sha2-nistp256
debug1: kex: server->client cipher: aes256-gcm@openssh.com MAC: <implicit>
compression: none
debug1: kex: client->server cipher: aes256-gcm@openssh.com MAC: <implicit>
compression: none
debug1: kex: curve25519-sha256 need=32 dh_need=32
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: SSH2_MSG_KEX_ECDH_REPLY received
debug1: Server host key: ecdsa-sha2-nistp256
SHA256:9Rj8e6GTNUeah218p0NaUqh143OD/90r2+MPpv90yeQ
file or directory
directory
directory
debug1: Host 'upload.osgeo.org' is known and matches the ECDSA host key.
debug1: Found key in /home/mneteler/.ssh/known_hosts:276
debug1: ssh_packet_send2_wrapped: resetting send seqnr 3
debug1: rekey out after 4294967296 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: ssh_packet_read_poll2: resetting read seqnr 3
debug1: SSH2_MSG_NEWKEYS received
debug1: rekey in after 4294967296 blocks
debug1: SSH2_MSG_EXT_INFO received
debug1: kex_ext_info_client_parse: server-sig-algs=<ssh-ed25519,sk-ssh-
ed25519@openssh.com,ssh-rsa,rsa-sha2-256,rsa-sha2-512,ssh-dss,ecdsa-
sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,sk-ecdsa-
sha2-nistp256@openssh.com,webauthn-sk-ecdsa-sha2-nistp256@openssh.com>
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue: publickey
debug1: Next authentication method: publickey
debug1: get_agent_identities: bound agent to hostkey
debug1: get_agent_identities: ssh_fetch_identitylist: agent contains no
identities
debug1: Will attempt key: /home/mneteler/.ssh/id_rsa RSA
SHA256:UNlrM0p4kYjM/HePNSGbZSMTSRqyjrXP7JVkB4Fi9FA
debug1: Will attempt key: /home/mneteler/.ssh/id_ecdsa
debug1: Will attempt key: /home/mneteler/.ssh/id_ecdsa_sk
debug1: Will attempt key: /home/mneteler/.ssh/id_ed25519 ED25519
SHA256:OnmnwV7PovBKQlb/98tRvCyPS4EUsJGXaShwUQSNDZI
debug1: Will attempt key: /home/mneteler/.ssh/id_ed25519_sk
debug1: Will attempt key: /home/mneteler/.ssh/id_xmss
debug1: Will attempt key: /home/mneteler/.ssh/id_dsa
debug1: Offering public key: /home/mneteler/.ssh/id_rsa RSA
debug1: Trying private key: /home/mneteler/.ssh/id_ecdsa
debug1: Trying private key: /home/mneteler/.ssh/id_ecdsa_sk
debug1: Offering public key: /home/mneteler/.ssh/id_ed25519 ED25519
debug1: Trying private key: /home/mneteler/.ssh/id_ed25519_sk
debug1: Trying private key: /home/mneteler/.ssh/id_xmss
debug1: Trying private key: /home/mneteler/.ssh/id_dsa
debug1: No more authentication methods to try.
grassbot@upload.osgeo.org: Permission denied (publickey).
(osgeo8: will create a new user on the other VM tomorrow or so)
Comment (by robe):
Replying to [comment:4 neteler]:
Okay I think issue is hopefully resolved now.
In order to connect to upload.osgeo.org, the account has to be part of
shell group.
I just added grassbot to shell via - https://id.osgeo.org/ldap/shell
For future you'll need to do that and should be able to since any shell
user can add another shell user.
Give it a try now.
Comment (by robe):
Just an FYI, you don't need to create a new user in grass.lxd,
it's the same deal that the user has to be in shell group for the ldap
auth to work on grass.
So by adding that already to shell group. You should be able to do on
grass
sudo su grassbot
and then I think I had set it to autocreate the home drive on first login.
So then you can add the public key to authorized_keys list of the grassbot
account.
osgeo7: also here I still cannot login successfully to upload.osgeo.org
with the "grassbot" user.
The current situation:
locally:
# locally .ssh/config
# ssh grassbot@osgeo7-download
# SAC Service Status - OSGeo
Host osgeo7-*
ProxyCommand ssh grassbot@hop.osgeo7.osgeo.org -W $(sed -e
"s/^osgeo7-//;s/$/.lxd/" <<< "%h"):%p
IdentityFile "~/.ssh/grassbot_osgeo"
server:
grassbot@download:~$ ls -la .ssh/authorized_keys
-rw-r--r-- 1 grassbot users 96 Mar 30 13:19 .ssh/authorized_keys
Now trying to login from outside:
mneteler@caddy: ~$ ssh -v grassbot@osgeo7-download
debug1: /home/mneteler/.ssh/config line 20: Applying options for osgeo7-*
debug1: /home/mneteler/.ssh/config line 30: Applying options for osgeo7-*
debug1: /home/mneteler/.ssh/config line 99: Applying options for *
ends/openssh.config
ends/openssh.config
debug1: identity file /home/mneteler/.ssh/old_id_ed25519 type 3
debug1: identity file /home/mneteler/.ssh/old_id_ed25519-cert type -1
osgeo8: I still cannot login successfully to grass.osgeo.org with the
"grassbot" user.
locally:
# locally: ssh key
mneteler@caddy: ~$ ls -la .ssh/grassbot_osgeo*
-rw------- 1 mneteler mneteler 464 Mar 19 14:48 .ssh/grassbot_osgeo
-rw-r--r-- 1 mneteler mneteler 96 Mar 19 14:48 .ssh/grassbot_osgeo.pub
# locally: .ssh/config
host grasslxd-grassbot
Hostname grass.lxd
ProxyCommand ssh grassbot@hop.osgeo8.osgeo.org -W %h:%p
User grassbot
server:
# server side (the grassbot user is now there and I can sudo into it)
# ssh pub key is registered
grassbot@grass:~$ ls -la .ssh/
total 3
drwx------ 2 grassbot users 3 Mar 30 13:01 ./
drwxr-xr-x 4 grassbot users 11 Mar 30 13:12 ../
-rw-r--r-- 1 grassbot users 96 Mar 30 13:01 authorized_keys
ssh -v grasslxd-grassbot
debug1: /home/mneteler/.ssh/config line 12: Applying options for grasslxd-
grassbot
ends/openssh.config
ends/openssh.config
debug1: Executing proxy command: exec ssh grassbot@hop.osgeo8.osgeo.org -W
grass.lxd:22
grassbot@hop.osgeo8.osgeo.org: Permission denied (publickey).
Comment (by robe):
You shouldn't have to generate one if things are working.
Can you do
su grassbot
and then create ssh keys for that account
Comment (by robe):
@neteler,
To rule out something wrong with the key, can you temporarily add the key
you normally use to the
https://id.osgeo.org/ldap/edit (logged in as grassbot)
to the list and try to log in as grassbot@upload.osgeo.org with your key?
Comment (by robe):
@neteler,
Also if you have time maybe we can do have a meeting at
https://meet.osgeo.org/SAC to go over.
At a glance not seeing anything wrong with your setup.
**osgeo7 / upload.osgeo.org**: success!
So:
- I have generated a new ssh key *on* grass.osgeo.org (using `su
grassbot`), and
- deposited the pub key in LDAP
- copied the key-pair locally to my laptop to be able to login from here.
Now access works:
mneteler@caddy: ~/.ssh$ ssh -i ~/.ssh/grassbot_grass_osgeo
Enter passphrase for key '/home/mneteler/.ssh/grassbot_grass_osgeo':
Linux download 5.15.0-105-generic #115~20.04.1-Ubuntu SMP Mon Apr 15
17:33:04 UTC 2024 x86_64
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
**osgeo8 / grass.osgeo.org**: not success yet. I guess that the hop server
is causing troubles? I guess I am close, though:
mneteler@caddy: ~$ ssh -v -i ~/.ssh/grassbot_grass_osgeo
grassbot@hop.osgeo8.osgeo.org -W grass.lxd:22
ends/openssh.config
ends/openssh.config
debug1: Connecting to hop.osgeo8.osgeo.org [140.211.15.9] port 22.
debug1: identity file /home/mneteler/.ssh/grassbot_grass_osgeo type 3
debug1: identity file /home/mneteler/.ssh/grassbot_grass_osgeo-cert type
-1
debug1: Remote protocol version 2.0, remote software version OpenSSH_8.4p1
Debian-5+deb11u1
debug1: compat_banner: match: OpenSSH_8.4p1 Debian-5+deb11u1 pat OpenSSH*
compat 0x04000000
debug1: Authenticating to hop.osgeo8.osgeo.org:22 as 'grassbot'
file or directory
directory
directory
debug1: kex: host key algorithm: ssh-ed25519
compression: none
compression: none
debug1: Server host key: ssh-ed25519
SHA256:+fn0UTxAYVJu8TN9R8bQDmf3yYj/c8HEphohFPkos7E
file or directory
directory
directory
debug1: Host 'hop.osgeo8.osgeo.org' is known and matches the ED25519 host
key.
debug1: Found key in /home/mneteler/.ssh/known_hosts:352
identities
debug1: Will attempt key: /home/mneteler/.ssh/grassbot_grass_osgeo ED25519
SHA256:PPF4X/w/W6Q55L2p3S65ZPqoVh7FbuOT6cF2driAUcA explicit
debug1: Offering public key: /home/mneteler/.ssh/grassbot_grass_osgeo
ED25519 SHA256:PPF4X/w/W6Q55L2p3S65ZPqoVh7FbuOT6cF2driAUcA explicit
debug1: Server accepts key: /home/mneteler/.ssh/grassbot_grass_osgeo
Authenticated to hop.osgeo8.osgeo.org ([140.211.15.9]:22) using
"publickey".
debug1: pkcs11_del_provider: called, provider_id = (null)
debug1: channel_connect_stdio_fwd: grass.lxd:22
debug1: channel 0: new stdio-forward [stdio-forward] (inactive timeout: 0)
debug1: Requesting no-more-sessions@openssh.com
debug1: Entering interactive session.
debug1: pledge: filesystem
debug1: client_input_global_request: rtype hostkeys-00@openssh.com
want_reply 0
debug1: client_input_hostkeys: searching /home/mneteler/.ssh/known_hosts
for hop.osgeo8.osgeo.org / (none)
debug1: client_input_hostkeys: searching /home/mneteler/.ssh/known_hosts2
debug1: client_input_hostkeys: hostkeys file
/home/mneteler/.ssh/known_hosts2 does not exist
debug1: client_input_hostkeys: no new or deprecated keys from server
debug1: pledge: agent
debug1: Remote: /etc/ssh/ssh-ldap-publickey:2: key options: agent-
forwarding port-forwarding pty user-rc x11-forwarding
SSH-2.0-OpenSSH_8.4p1 Debian-5+deb11u4
debug1: channel 0: FORCE input drain
Invalid SSH identification string.
debug1: stdio forwarding: done
Comment (by annakrat):
@robe, it looks like there is still some problem, any idea? Thanks
Comment (by robe):
Replying to [comment:14 annakrat]:
@neteler is there still an issue. I'm seeing a folder in /home/grassbot
called code_and_data@ of grass.lxd that looks to have a ton of folders in
it. So I assume that means you were successful?
osgeo8: still not working. The folder I made via sudo from my own account.
ssh -i ~/.ssh/grassbot_grass_osgeo grassbot@hop.osgeo8.osgeo.org -W
grass.lxd:22
@robe
I checked and can at least log into the hop server:
mneteler@caddy: ~$ ssh -i ~/.ssh/grassbot_grass_osgeo
Linux hop 5.15.0-113-generic #123-Ubuntu SMP Mon Jun 10 08:16:17 UTC 2024
x86_64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Last login: Tue Apr 8 19:51:26 2025 from 127.0.0.1
grassbot@hop:~$
So "only" the forwarding to grass.lxd is failing.
Do you have any idea?
`ssh -i ~/.ssh/grassbot_grass_osgeo grassbot@hop.osgeo8.osgeo.org -W
grass.lxd:22`
Is my ssh command wrong? Thanks for any support.
Comment (by robe):
Replying to [comment:17 neteler]:
> @robe
grass.lxd:22`
Haven't used that syntax. Only used the adding into my config.
But from reading, I think you need a -J command to use a jump host.
Try this:
ssh -i ~/.ssh/grassbot_grass_osgeo -J grassbot@hop.osgeo8.osgeo.org
grassbot@grass.lxd
Thanks, @robe. Still no access:
grassbot@grass.lxd
I wonder why it works for "neteler" user but not for "grassbot".
