[OSGeo] #3386: Requesting Nexus Repository Access
Reporter: patrickvmadden | Owner: sac-tickets@…
     Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: SysAdmin | Keywords:
My userid is patrickvmadden
I'm attempting to add Repository - Sonatype Nexus Repository as a
remote repository to our public artifactory server located at
https://repository.tomsawyer.com
I am working on a project that requires access to:
<!-- https://mvnrepository.com/artifact/org.geotools/gt-main -->
<dependency>
     <groupId>org.geotools</groupId>
     <artifactId>gt-main</artifactId>
     <version>33.0</version>
</dependency>
Which is located at Repository - Sonatype Nexus Repository that I
believe is available from Repository - Sonatype Nexus Repository
Any help is greatly appreciated.
Thank You,
Patrick Madden
pmadden@tomsawyer.com
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3386&gt;
OSGeo <Gter - OSGeo;
Reporter: patrickvmadden | Owner: jive
Component: SysAdmin/Repo | Resolution:
Keywords: |
Changes (by robe):
* component: SysAdmin => SysAdmin/Repo
* owner: sac-tickets@… => jive
Comment:
@patrickvmadden what problem are you running into with adding this.
Perhaps @jive can help with that.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3386#comment:1&gt;
Keywords: |
Comment (by patrickvmadden):
I'm trying to follow the instructions as defined here:
SAC:Repo - OSGeo
Specifically related to "How to integrate with Artifactory as a remote
repository"
I work on a very important project that uses Artifactory as our main
repository and we would like to add osgeo's Nexus repository as a remote
repository to our artifactory.
I have a userid but it says to:
1. Create a TRAC ticket Making sure you're not a bot! requesting repo
access with the name of your project, and OSGeo UserID requiring access. A
project repository (maphappy-releases) will be setup, with access granted
to the OSGeo UserID requested.
So, that is what I've done. I still get 403 forbidden when trying to
download osgeo artifacts.
Thanks for any help.
Ticket URL: <Making sure you're not a bot!;
Keywords: |
Comment (by robe):
Just to rule out some permissions issue, from the server you are trying to
add the repo, can you get to the directory browsing fine?
Keywords: |
When I login to repo.osgeo.org with my username and password I cannot see
anything when directory browsing?
I see the following:
Browse feature is not available as you do not have the required
permissions
When I am not logged in I can directory browse...
Does that make sense?
Keywords: |
Comment (by robe):
Replying to [comment:4 patrickvmadden]:
see anything when directory browsing?
permissions
Hmm that is strange. So you can browse if you are anonymous but not if
you are logged in?
Doesn't make sense to me.
I can browser regardless if I am logged in or not, but might be because my
permissions are higher.
@jive any thoughts on this. I'm at a loss what is going on here.
Keywords: |
Not sure what is happening either as I'm trying to follow the instructions
listed on your site.
SAC:Repo - OSGeo
repository"
I followed all the instructions? Can anyone check if my userid
patrickvmadden has been provided with read permissions to the appropriate
repositories?
