[OSGeo] #3391: discourse.osgeo.org change dmarc from report to reject
Reporter: robe | Owner: sac-tickets@…
     Type: task | Status: new
Priority: normal | Milestone: 2025 (robe)
Component: SysAdmin/Discourse | Keywords:
Did this yesterday, so this is just have a record of the change.
This is to prevent mail servers impostering as discourse.osgeo.org
Ticket URL: <Making sure you're not a bot!;
OSGeo <Gter - OSGeo;
Component: SysAdmin/Discourse | Resolution:
Keywords: |
Comment (by robe):
Okay need to revert looks like DMARC is failing.
Keywords: |
Comment (by robe):
changed
_dmarc.discourse from "v=DMARC1; p=none; rua=mailto:dmarc@osgeo.org;
ruf=mailto:dmarc@osgeo.org; fo=s"
_dmarc.discourse to "v=DMARC1; p=reject; rua=mailto:dmarc@osgeo.org;
I need to confirm email is working before I close this out.
Keywords: |
Comment (by strk):
I've enabled DKIM signing for email coming from lists.osgeo.org - see
deployment/commit/39815fb92f4197ca1831d0fa683473d8e5638dd3
It may (or may not) help with the DMARC policy (how does it fail?)
Keywords: |
Comment (by robe):
doesn't look like it's DKIM signed at all but it might be something else
cause I'm redirecting my mail to my postgis.net alias so I don't get
bombarded with email on my business address.
email from mantra-request is failing DMARC too. Can you check the header
of that and see if that fails for you.
When I had DMARC reject on the emails were going to SPAM instead of inbox
and when I set it back to none it came thru my inbox.
