[OSGeo] #3392: update pretalx to newer verson
Reporter: astrid_emde | Owner: sac-tickets@…
     Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: SysAdmin | Keywords: pretalx
Looks like we are using an older pretalx version.
The issue was reported by Tobias Preuss who uses the xml export for the
app. This export has missing speaker info, which should be solved already
by ticket schedule.xml export / persons node missing · Issue #1694 · pretalx/pretalx · GitHub (may 2024)
- Find out more about the versions Tags · pretalx/pretalx · GitHub
- see OSGeo Wiki about pretalx Pretalx - OSGeo
Ticket URL: <Making sure you're not a bot!;
OSGeo <Gter - OSGeo;
#3392: update pretalx to newer version
Component: SysAdmin | Resolution:
Keywords: pretalx |
Changes (by astrid_emde):
* summary: update pretalx to newer verson => update pretalx to newer
              version
Keywords: pretalx |
Comment (by robe):
unfortunately I think this will need to wait cause pretalx takes a bit to
upgrade and we have reduced SAC hours for this year and also need to focus
on SAC data center migration which will be happening this year.
