#3397: Transfer of pgRouting domain names
Reporter: dkastl | Owner: sac-tickets@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: SysAdmin | Keywords:
I would like to do a domain name transfer to OSGeo for the following
domains:
- pgrouting.org
- pgrouting.info
- pgrouting.net
- pgrouting.com
Their DNS are managed through Cloudflare at the moment and this should not
change.
I will send the transfer authorisation codes via email.
Ticket URL: <Making sure you're not a bot!;
OSGeo <Gter - OSGeo;
Component: SysAdmin | Resolution:
Keywords: |
Comment (by cvvergara):
We are not bothering with .info its expensive.
We have the following message:
The transfer of the following domain names has been initiated:
pgrouting.com
pgrouting.net
Your current registrar still needs to approve the transfer and they may
email you about it. This email will have instructions on how to cancel the
transfer. As long as you do not cancel the transfer, it should be
completed.
We will wait for the transfer code of pgRouting.org
TODO:
The nameserver in cloudflare
Keywords: |
Comment (by robe):
The transfer of pgrouting.com and pgrouting.net completed and it auto-
added back the cloudflare dns entries so no need to add the cloudflare
nameservers
Keywords: |
Comment (by dkastl):
`pgrouting.org` seems to be in a 60 days domain transfer lock, because
[FAQ · Cloudflare Registrar docs
transfer-my-domain "ICANN prohibits domain transfers within 60 days of a
change to the WHOIS data or registrar of a domain."], so I can't currently
request the authentication code and we have to wait until middle of
September to make the transfer.
Keywords: |
I initiated the transfer for `pgrouting.org` and sent the authorisation
code via email.
Type: task | Status: closed
Component: SysAdmin | Resolution: fixed
Keywords: |
Changes (by robe):
* resolution: => fixed
* status: new => closed
Comment:
I was able to use the authorization code and purchased for 5 years at $55.
Figured we should take advantage of the 50% off sale. It says the
transfer is still going on so I guess we'll get notification once it's
complete. As I recall I think it automatically picks up the NS records so
there should be nothing we need to do after. DNS will still be hosted on
cloudflare.com which we should keep.
I'm going to mark this as closed and reopen if we still have issues.
