[OSGeo] #3404: gitea no longer provides tarball links
Reporter: Bas Couwenberg | Owner: strk
     Type: defect | Status: new
Priority: normal | Milestone: Unplanned
Component: SysAdmin/Gitea | Keywords:
The tags page used to provide links to download tarballs and zip files,
these are used by the Debian packaging for librttopo & php-geos to monitor
and download new upstream releases.
See for example: Making sure you're not a bot!
The Downloads section for specific tags is also empty.
The API still contains these links:
     "name": "1.0.0",
     "message": "Release 1.0.0",
     "id": "9d63f62b5d0303f590dfe98662e501ecd7aaccc6",
     "commit": {
       "url": "Making sure you're not a bot!
geos/git/commits/9d63f62b5d0303f590dfe98662e501ecd7aaccc6",
       "sha": "6db47f00c7b6902b4e74e0bdb057ffc9ccaa906a",
       "created": "2017-12-21T11:33:18+01:00"
     "zipball_url": "Making sure you're not a bot!
geos/archive/1.0.0.zip",
     "tarball_url": "Making sure you're not a bot!
geos/archive/1.0.0.tar.gz"
But these results in 404 responses:
--2025-07-28 20:17:13-- Making sure you're not a bot!
Resolving git.osgeo.org (git.osgeo.org)... 140.211.15.57
Connecting to git.osgeo.org (git.osgeo.org)|140.211.15.57|:443...
connected.
HTTP request sent, awaiting response... 404 Not Found
2025-07-28 20:17:13 ERROR 404: Not Found.
Ticket URL: <Making sure you're not a bot!;
OSGeo <Gter - OSGeo;
