On behalf of the PROJ development team I am happy to announce the
release of PROJ 6.2.1. See release notes below for details.
Download the source distribution here:
https://download.osgeo.org/proj/proj-6.2.1.tar.gz (https://download.osgeo.org/proj/proj-6.2.1.tar.gz.md5)
https://download.osgeo.org/proj/proj-6.2.1.zip (https://download.osgeo.org/proj/proj-6.2.1.zip.md5)
6.2.1 Release Notes
Updates
o Update the EPSG database to version 9.8.2
Bug fixes
o Fixed erroneous spelling of “Potsdam” (#1573)
o Calculate y-coordinate correctly in bertin1953 in all cases (#1579)
o proj_create_crs_to_crs_from_pj(): make the PJ* arguments const PJ* (#1583)
o PROJStringParser::createFromPROJString(): avoid potential infinite
recursion (#1574)
o Avoid core dump when setting ctx==NULL in functions
proj_coordoperation_is_instantiable and
proj_coordoperation_has_ballpark_transformation (#1590)
o createOperations(): fix conversion from/to PROJ.4 CRS strings with
non-ISO-kosher options and +towgs84/+nadgrids (#1602)
o proj_trans_generic(): properly set coordinate time to HUGE_VAL when no
value is passed to the function (#1604)
o Fix support for +proj=ob_tran +o_proj=lonlat/latlong/latlon instead of only
only allowing +o_proj=longlat (#1601)
o Improve backwards compatibility of vertical transforms (#1613)
o Improve emulation of deprecated +init style initialization (#1614)
o cs2cs: autopromote CRS to 3D when there’s a mix of 2D and 3D (#1563)
o Avoid divisions by zero in odd situations (#1620)
o Avoid compile error on Solaris (#1639)
o proj_create_crs_to_crs(): fix when there are only transformations with
ballpark steps (#1643)
o PROJ string CRS ingester: recognize more unit-less parameters, and general
handling of +key=string_value parameters (#1645)
o Only call pkg-config in configure when necessary (#1652)
o aeqd: for spherical forward path, go to higher precision ellipsoidal
case when the point coordinates are super close to the origin (#1654)
o proj_create_crs_to_crs(): remove elimination of Ballpark operations
that caused transformation failures in some cases (#1665)
o createOperations(): allow transforming from a compoundCRS of a bound
verticalCRS to a 2D CRS (#1667)
o Avoid segfaults in case of out-of-memory situations (#1679)
o createOperations(): fix double vertical unit conversion from CompoundCRS
to other CRS when the horizontal part of the projected CRS uses non-metre
unit (#1683)
o importFromWkt(): fix axis orientation for non-standard ESRI WKT (#1690)
