On behalf of the GDAL/OGR development team and community, I am pleased to
announce the release of GDAL/OGR 2.2.0. GDAL/OGR is a C++ geospatial
data access library for raster and vector file formats, databases and
web services. It includes bindings for several languages, and a variety
of command line tools.
The 2.2.0 release is a major new feature release with the following
highlights:
- New GDAL/raster drivers:
DERIVED driver: read-support. Expose subdatasets in a a new metadata domain, called DERIVED_SUBDATASETS
JP2Lura driver: read/create support for JPEG-2000 images using Luratech JP2 Library
PRF: add read-only support for PHOTOMOD PRF file format driver (github #173)
RRASTER driver: read-support .grd/.gri files handled by the R ‘raster’ package (#6249)
- New OGR/vector drivers:
CAD driver: read support for DWG R2000 files (GSoC 2016 project)
DGNv8 driver: read-write support for DGN 8.0 format (using Teigha ODA libraries)
GMLAS driver: read-write support. XML/GML driver driven by Application Schemas.
New utility script: ogrmerge.py to merge several vector datasets into a single one
New /vsigs/ and /vsigs_streaming/ virtual file systems to read Google Cloud Storage non-public files
Significantly improved drivers:
NWT_GRD: write support (#6533)
FileGDB/OpenFileGDB: add support to read curve geometries (#5890)
VRT derived band: add the capability to define pixel functions in Python
Add read support for RasterLite2 coverages in SQLite driver
GPKG: implement tiled gridded elevation data extension
ISIS3: add write support and improve read support
- RFC 63: Add GDALRasterBand::GetDataCoverageStatus() and implement it in GTiff and VRT drivers
https://trac.osgeo.org/gdal/wiki/rfc63_sparse_datasets_improvements
- RFC 64: Triangle, Polyhedral surface and TIN
https://trac.osgeo.org/gdal/wiki/rfc64_triangle_polyhedralsurface_tin
==> this RFC introduces potential backward incompatible behaviour.
Consult MIGRATION_GUIDE.txt
- RFC 66: OGR random layer read/write capabilities
https://trac.osgeo.org/gdal/wiki/rfc66_randomlayerreadwrite
- RFC 67: add null field state for OGR features, in addition to unset fields
https://trac.osgeo.org/gdal/wiki/rfc67_nullfieldvalues
Upgrade to EPSG database v9.0 (#6772)
Python bindings: Global Interpreter Lock (GIL) released before entering GDAL native code (for all, in GDAL module and a few ones in ogr like ogr.Open())
Continued major efforts on sanitization of code base
Remove bridge and vb6 bindings (#6640)
GNM built by default
More complete information on the new features and fixes in the 2.2.0
release can be found at:
http://trac.osgeo.org/gdal/wiki/Release/2.2.0-News
The release can be downloaded from:
http://download.osgeo.org/gdal/2.2.0/gdal220.zip - source as a zip
http://download.osgeo.org/gdal/2.2.0/gdal-2.2.0.tar.gz - source as
.tar.gz
.tar.xz
http://download.osgeo.org/gdal/2.2.0/gdal-grass-2.2.0.tar.gz - GDAL-GRASS plugin
http://download.osgeo.org/gdal/2.2.0/gdalautotest-2.2.0.tar.gz - test
suite
- http://download.osgeo.org/gdal/2.2.0/gdal220doc.zip - documentation /
website
The migration guide can be found at :
https://svn.osgeo.org/gdal/branches/2.2/gdal/MIGRATION_GUIDE.TXT
Best regards,
Even
Spatialys - Geospatial professional services
