On behalf of the GDAL/OGR development team and community, I am pleased to
announce the release of GDAL/OGR 2.0.0. GDAL/OGR is a C++ geospatial
data access library for raster and vector file formats, databases and
web services. It includes bindings for several languages, and a variety
of command line tools.
The 2.0.0 release is a major new feature release with the following
highlights:
* GDAL and OGR driver and dataset unification:
http://trac.osgeo.org/gdal/wiki/rfc46_gdal_ogr_unification
* Support for curve geometries:
http://trac.osgeo.org/gdal/wiki/rfc49_curve_geometries
* Support for OGR field subtypes (boolean, int16, float32):
http://trac.osgeo.org/gdal/wiki/rfc50_ogr_field_subtype
* RasterIO() improvements : resampling and progress callback
http://trac.osgeo.org/gdal/wiki/rfc51_rasterio_resampling_progress
* Stricter SQL quoting:
http://trac.osgeo.org/gdal/wiki/rfc52_strict_sql_quoting
* OGR not-null constraints and default values:
http://trac.osgeo.org/gdal/wiki/rfc53_ogr_notnull_default
* OGR dataset transactions:
https://trac.osgeo.org/gdal/wiki/rfc54_dataset_transactions
* Refined SetFeature() and DeleteFeature() semantics:
https://trac.osgeo.org/gdal/wiki/rfc55_refined_setfeature_deletefeature_semantics
* OFTTime/OFTDateTime millisecond accuracy:
https://trac.osgeo.org/gdal/wiki/rfc56_millisecond_precisio
* 64bit histogram bucket count:
https://trac.osgeo.org/gdal/wiki/rfc57_histogram_64bit_count
* 64-bit integer fields and feature IDs :
https://trac.osgeo.org/gdal/wiki/rfc31_ogr_64
* New GDAL drivers:
- BPG: read-only driver for Better Portable Graphics format (experimental)
- GPKG: read/write/update capabilities in the unified raster/vector driver
http://gdal.org/drv_geopackage_raster.html
- KEA: read/write driver for KEA format
http://gdal.org/frmt_kea.html
- PLMosaic: read-only driver for Planet Labs Mosaics API
http://gdal.org/frmt_plmosaic.html
- ROI_PAC: read/write driver for image formats of JPL's ROI_PAC project
http://www.gdal.org/frmt_various.html#ROI_PAC
- VICAR: read-only driver for VICAR format
http://www-mipl.jpl.nasa.gov/external/vicar.html
* New OGR drivers:
- Cloudant : read/write driver for Cloudant service
http://gdal.org/drv_cloudant.html
- CSW: read-only driver for OGC CSW (Catalog Service for the Web) protocol
http://gdal.org/drv_csw.html
- JML: read/write driver for OpenJUMP .jml format
http://gdal.org/drv_jml.html
- PLScenes: read-only driver for Planet Labs Scenes API
http://gdal.org/drv_plscenes.html
- Selaphin: read/write driver for the Selaphin/Seraphin format
http://gdal.org/ogr/drv_selafin.html
* Significantly improved drivers: CSV, GPKG, GTiff, JP2OpenJPEG, MapInfo, PG,
SQLite
* Upgrade to EPSG 8.5 database
* Fix locale related issues when formatting or reading floating point numbers
More complete information on the new features and fixes in the 2.0.0
release can be found at:
http://trac.osgeo.org/gdal/wiki/Release/2.0.0-News
The release can be downloaded from:
* http://download.osgeo.org/gdal/2.0.0/gdal200.zip - source as a zip
* http://download.osgeo.org/gdal/2.0.0/gdal-2.0.0.tar.gz - source as
.tar.gz
* http://download.osgeo.org/gdal/2.0.0/gdal-2.0.0.tar.xz - source as
.tar.xz
* http://download.osgeo.org/gdal/2.0.0/gdalautotest-2.0.0.tar.gz - test
suite
* http://download.osgeo.org/gdal/2.0.0/gdal200doc.zip - documentation /
website
As there have been a few changes to the C++ API, and to a lesser extent to the
C API, developers are strongly advised to read :
https://svn.osgeo.org/gdal/branches/2.0/gdal/MIGRATION_GUIDE.TXT
Best regards,
Even
Spatialys - Geospatial professional services
http://www.spatialys.com
