[OSGeo-Announce] pgRouting version 3.4.1, 3.4.0 and version 3.3.5, 3.3.4 release
Published at https://www.osgeo.org/foundation-news/pgrouting-version-3-4-1-3-4-0-and-version-3-3-5-3-3-4-release/
News item by Ashish Kumar
Hello pgRouting community,
The pgRouting Team is pleased to announce the release of pgRouting versions 3.4.1, 3.4.0 and 3.3.5, 3.3.4
The latest release is available at [1]
The fixes were backported to the previous versions [2]
To see all issues & pull requests closed by version 3.4.1, see the Git closed milestone for 3.4.1 [3]
Issue fixes
  • #2401: pgRouting 3.4.0 do not build docs when sphinx is too low or missing
  • #2398: v3.4.0 does not upgrade from 3.3.3
To see all issues & pull requests closed by version 3.4.0, see the Git closed milestone for 3.4.0 [4]
Issue fixes
  • #1891: pgr_ksp doesn’t give all correct shortest path
New proposed functions
  • With points
  • pgr_withPointsVia (One Via)- Turn Restrictions
  • Via with turn restrictions
  • pgr_trspVia (One Via)
  • pgr_trspVia_withPoints (One Via)- pgr_trsp
  • pgr_trsp (One to One)
  • pgr_trsp (One to Many)
  • pgr_trsp (Many to One)
  • pgr_trsp (Many to Many)
  • pgr_trsp (Combinations)- pgr_trsp_withPoints
  • pgr_trsp_withPoints (One to One)
  • pgr_trsp_withPoints (One to Many)
  • pgr_trsp_withPoints (Many to One)
  • pgr_trsp_withPoints (Many to Many)
  • pgr_trsp_withPoints (Combinations)- Topology
  • pgr_degree- Utilities
  • pgr_findCloseEdges (One point)
  • pgr_findCloseEdges (Many points)
    New experimental functions
  • Ordering
  • pgr_cuthillMckeeOrdering- Unclassified
  • pgr_hawickCircuits
    Official functions changes
  • Flow functions
  • pgr_maxCardinalityMatch(text)
  • Deprecating pgr_maxCardinalityMatch(text,boolean)
    Deprecated functions
  • Turn Restrictions
  • pgr_trsp(text,integer,integer,boolean,boolean,text)
  • pgr_trsp(text,integer,float8,integer,float8,boolean,boolean,text)
  • pgr_trspViaVertices(text,anyarray,boolean,boolean,text)
  • pgr_trspViaEdges(text,integer,float,boolean,boolean,text)
To update your database:
Download the packaged version from your operating system, and use this command in the database:
ALTER EXTENSION pgrouting UPDATE TO “3.4.1”;
[1] https://github.com/pgRouting/pgrouting/releases/latest
[2] https://github.com/pgRouting/pgrouting/releases
[3] https://github.com/pgRouting/pgrouting/issues?utf8=%E2%9C%93&q=milestone%3A%22Release%203.4.1%22
[4] https://github.com/pgRouting/pgrouting/issues?utf8=%E2%9C%93&q=milestone%3A%22Release%203.4.0%22
pgRouting Team.
