[OSGeo-Announce] PROJ 4.8.0 Released
Folks,
I am pleased to announce the release of PROJ 4.8.0. This is a
major new feature release and collects all the work done since
the PROJ 4.7.0 release in September 2009. The NEWS file includes
these major items:
* Added the Natural Earth projection.
* Added HEALPIX, rHEALPIX and Icosahedral Snyder Equal Area projections.
* nad2bin now produces "CTable2" format grid shift files by default which
  are platform independent.
* nad2nad removed, use cs2cs for datum shift operations.
* projects.h no longer installed as a public include file. Please try to
   only use proj_api.h.
* Add pj_get_spheroid_defn() accessor.
* Added an alternate version of pj_init() that takes a projCtx (execution
   context) structure to address multithreading issues with error management
   and to provide a support for application hookable error reporting and
   logging.
* Upgrade to EPSG 7.9. Some changes in ideal datum selection.
* JNI bindings reworked, org.proj4.Projections deprecated in favor of
   org.proj4.PJ.
* Added preliminary vertical datum support.
* Fix various multithreading issues, particular in datum grid handling code.
* Added support for the +axis= option for alternate axis orientations as
   part of a coordinate system (used for TM South Orientated support).
* +proj=omerc implementatioin replaced with code from libproj4. +rot_conv
   flag no longer works, and some coordinate systems (ie. Malaysian) will
   need to use +gamma instead. "epsg" init file updated accordingly.
More detailed information on work can be found in the ChangeLog file at:
http://svn.osgeo.org/metacrs/proj/tags/4.8.0/proj/ChangeLog
The source code can be found at:
http://download.osgeo.org/proj/proj-4.8.0.tar.gz
http://download.osgeo.org/proj/proj-4.8.0.zip
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | Geospatial Software Developer
