[OSGeo-Announce] ZOO-Project 1.4.0 release
Hello OSGeo community, and ZOO-Project users!
The ZOO-Project development team is pleased to announce the ZOO-Project
1.4.0 release [1].
This release should work correctly on both GNU/Linux, MacOS X and WIN32
platforms.
You can download the archives from [2] (zip) and [3] (tar.bz2) or use
Subversion:
   svn co http://svn.zoo-project.org/svn/tags/rel-1.4.0/
   zoo-project-1.4.0
The most important modifications / fixes are listed below:
  * Small fix for mimeType of results for CGAL services
  * Binary support for PHP language
  * ZOO-API for the Java language
  * ZOO-Client Javascript API
  * FastCGI fixes
  * JavaScript ZOO-API enhancements (COOKIE use and Output in generated
    XML)
  * Add debian files
  * Inputs passed by reference downloaded in parallel
  * Conform behavior for DescribeProcess when the Identifier was not
    found
  * Add support of maximumMegabytes keywords for ComplexData Inputs
  * Add the optional YAML ZCFG support #4 and the zcfg2yaml converter
  * Return error messages that enable the service provider to quickly
identify the root cause of errors due to configuration file syntax
(ticket #90)
  * Fix logic in addMapToMap (ticket #91)
  * Enable AllowedValue and multiple Range definitions using default
    and supported blocks
  * Add the lastest revision number in version.h (available in Python
ZOO-API)
  * Add the optional Ruby Language Support to the ZOO-Kernel with an
    API similar to the Python ZOO-API
  * Small rewrite of Python support
  * Inputs can be requested over https protocol (ticket #86)
  * Add capability to define both percentage of execution and a message
(ticket #87).
  * Add usid in lenv section used to generate an unique identifier
    based on time and the process identifier.
  * Add gdal_contour service
  * Add dynamic definition of serverAddress from the main section
This work was supported by a grant from the European Union's 7th
Framework Programme (2007-2013) provided for the project PublicaMundi
(GA no. 609608).
I hope you can have good time using this new ZOO-Project release,
Best regards,
Gérald Fenoy
ZOO-PSC Chair
[1] http://www.zoo-project.org/site/Downloads#ZOO-Projectversion1.4.0
[2] http://zoo-project.org/dl/zoo-project-1.4.0.zip
[3] http://zoo-project.org/dl/zoo-project-1.4.0.tar.bz2
