osgeo4 deployment mismatch with Ansible
Preparing to add the new mail server container to the set of backed up
containers I found out that the "osgeo4" state is not the one
requested by our Ansible based playbook.
This is how to check:
    make check-osgeo4 ANSIBLE_CONFIG=ansible.osgeo.prod.cfg
The command above shows a few changes that would be made to the
running system and I wonder which of them are really wanted and
which are not, these are:
  x. Backup scripts would change
     The version of the backup scripts on osgeo4 is different
     from the version in ansible. Weird enough, the version on
     the machine contains a comment stating "Managed via ansible"
     while the version in ansible does NOT have the comment.
     Moreover, there's a git repository on the root dir of osgeo4
     but only partially containing the /backup dir and having
     local changes on that partially covered set.
     Shall I update ansible to match production ?
  x. An "ansible-control" container would be created
     On the host we have both "ansible-dev" and "ansible-dev-old"
     containers, and BOTH are in RUNNING state, shall I drop them
     both and let the ansible playbook do its thing ?
  x. The "osgeo4-nginx" container would get proxied 140.211.15.32:8081
     The proxy name would be "proxyportacme", suggesting this was for
     LetsEncrypt, but I don't think letsencrypt uses port 8081 and the
     current server is NOT proxying it,
     shall I drop that from the playbook ?
     NOTE: this was probably added by accident in an unrelated commit:
           Making sure you're not a bot!
           ( addition of add-download2.yml is also an accident ? )
--strk;
  Libre GIS consultant/developer :trumpet:
  strk's services
--strk;
  strk's services
I've dropped ansible-dev-old. Leave ansible-dev alone as I'm using that one and wasn't built from Ansible.
How's ansible-dev supposed to be different from ansible-control ?
Could we just rename it to be in agreement with Ansible ?
--strk;
one
--strk;
I don't know what ansible-control is. Is that something you created?
I setup ansible-dev to work on ansible and it has my home account and
password key on it and configured just the way I want it.
Too difficult to do ansible work on my desktop.
It came into ansible-deployment 2 years ago:
https://gitea.osgeo.org/sac/ansible-deployment/commit/e62d15fd3cd982c17550024fd6746cf2c1b10153
and was tweaked again first to allow for nesting:
https://gitea.osgeo.org/sac/ansible-deployment/commit/6c5a85abc9fc996787133237f439e484568face7
and than to be for debian-12:
https://gitea.osgeo.org/sac/ansible-deployment/commit/35df8371eb0955af84060fed77708f5511f02d2f
Check out deployment/roles/osgeo4/tasks/main.yml - how about we rename your ansible-dev to
ansible-control and check that deploying tag container_ansible of osgeo4 role doesn't introduce any change ?
Yes I remember this, it's probably the main reason why ansible-control was planned
--strk;
